Ground Crontrol Coil overs spring rates.
Old Dec 8, 2002 | 05:26 PM
Soulless's Avatar
Default Ground Crontrol Coil overs spring rates.
Does anyone know where to check which springs rate i have?? I picked up a full set of them at a local junk yard off a 97 integra, i want to put them on my 93 Si hatch. i just wanna know wht the rates are for autoX.
Old Dec 8, 2002 | 05:30 PM
-Gambit-'s Avatar
Default Re: Ground Crontrol Coil overs spring rates. (Soulless)
it will say on the spring itself somewhere around where it says eibach
Old Dec 9, 2002 | 05:57 PM
Soulless's Avatar
Default Re: Ground Crontrol Coil overs spring rates. (gambit33)
If that is so, then the rates are 200 and 180. but those dont sound right.
Old Dec 9, 2002 | 11:41 PM
psileepR's Avatar
New User
yep those are around the right spring rates... stock gc spring rates are really soft... if u want to upgrade them it costs around 50+ bucks per set... for custom rates
Old Dec 10, 2002 | 04:18 AM
BROOD's Avatar
Default Re: Ground Crontrol Coil overs spring rates. (Civtek)
Yep, stock spring rates on GC are usually around there depending on the car application.
Old Dec 11, 2002 | 09:33 AM
Soulless's Avatar
Default Re: Ground Crontrol Coil overs spring rates. (SLPR)
what would be some good spring rates for autoX,thats what i am plannin to do with my car. and i dont think 200 and 180 will do very well.
Old Dec 11, 2002 | 10:18 AM
sivik2nr's Avatar
cream of the crop? Get some of the not yet released Mugen kit when they come out... I think 1000lb. in front and 1800lb. in the rear. Not streetable at all! But can definately lower then lap times..
[Modified by sivik2nr, 1:19 PM 12/11/2002]
Old Dec 11, 2002 | 11:29 AM
ruthless013's Avatar
200/180 is NOT right, that's way too soft.
read the verbage on the spring letter for letter, we'll help you decipher it.
should be closer to 325/250 stock.
Old Dec 11, 2002 | 11:39 AM
ill phil's Avatar
Default Re: Ground Crontrol Coil overs spring rates. (ruthless013)
Actually I believe that 200/180 or close to that were the spring rates on the Ground Control "Special Edition" coilovers that were just for Civics, crxs, integras. They were softer than the normal sets and cheaper too.
Old Dec 16, 2002 | 01:49 PM
Soulless's Avatar
what the hell is the verbage???
Old Dec 16, 2002 | 01:57 PM
Rob Dizzle's Avatar
you can get custom setups from gc. the owner of the teg could have gone that route
just read the springs, or post some pics
singlecammin
Suspension & Brakes
Dec 26, 2010 12:16 PM
DA is best
Suspension & Brakes
Jul 7, 2007 11:15 PM
pjr710
Suspension & Brakes
19
Apr 19, 2007 02:44 PM
user 9782082308
Jan 16, 2003 07:25 AM
