which way is the way to take out the bolt off the pulley crank.?
Old Dec 8, 2002 | 04:05 PM
wizzards581's Avatar
Default which way is the way to take out the bolt off the pulley crank.?
i tried holdin the crank bolt against the ground and starting the car but it jumps the opposite way... does the crank spin counter or clockwise?
Old Dec 8, 2002 | 04:08 PM
Kataku2K3's Avatar
Default Re: which way is the way to take out the bolt off the pulley crank.? (wizzards581)
The bolt is still a standard thread... counterclockwise to loosten... an impact gun will do the trick or check out this post... https://honda-tech.com/zerothread?id=354164 HAHA MY BAD I DIDN'T REALIZE THAT YOU CREATED THIS OTHER POST... OH WELL
[Modified by JDMspecEG6, 5:10 PM 12/8/2002]
Old Dec 8, 2002 | 05:03 PM
Default Re: which way is the way to take out the bolt off the pulley crank.? (JDMspecEG6)
haha.. yea man... thanx.. ill wait for ur pics then... i jux need to get my car running.. thats my daily... and now im workin on weekdays.. so hard having one car and only tha weekends to fix...
Old Dec 8, 2002 | 07:50 PM
degooser's Avatar
take of the flywheel cover under your tranny and stick a screwdriver into your flywheel and then proceed to take off the crank pulley bolt.....
Old Dec 9, 2002 | 11:32 AM
Default Re: which way is the way to take out the bolt off the pulley crank.? (degooser)
i did that half way... does those bolts open the oil pan also?? how many bolts.. and pics would help...
Old Dec 9, 2002 | 12:26 PM
Kataku2K3's Avatar
If you are workin with a B series motor i know this for sure..... You'll have to take off the front and rear stabalizer brackets which hold the tranny to the block... they are 17mm on the tranny side and 12mm on the block side if i'm not mistaken.. You will also have a couple 12mm and 10mm bolts that hold the shield to the tranny... I don't work with SOHC motors that much but i'm pretty sure they do have a couple 10mm's that bolt the shield to the oil pan... Good Luck... it's really easy
Old Dec 9, 2002 | 12:29 PM
Zeus Zore's Avatar
the right way...
Old Dec 10, 2002 | 04:15 PM
degooser's Avatar
Default Re: which way is the way to take out the bolt off the pulley crank.? (Zeus Zore)
This was how we did it on my single cam....we had the impact wrench going and we still could not break the bolt...until we did what i posted above...
Old Dec 10, 2002 | 04:19 PM
-Whitey-'s Avatar
tap on the head of the bolt or tighten it a little to break it free then use an impact to zip it off(counter clockwise) follow these directions in reverse to reinstall
Old Dec 10, 2002 | 06:21 PM
intezn's Avatar
Default Re: which way is the way to take out the bolt off the pulley crank.? (one-syk)
air guns, took me like 30 minutes thought
Old Dec 10, 2002 | 06:41 PM
blackANESE's Avatar
OR take off your starter and put a screwdriver in there and hold it while you
Old Dec 10, 2002 | 06:46 PM
Civmochris's Avatar
i had to take two screw drivers put them through the holes on the pully take the biggest bar you have and use it to hold the pulley still let the bar rest against the axle and use the longest breaker bar and metal pipe u can find
Civmochris
Old Dec 10, 2002 | 07:25 PM
JeremyL's Avatar
Default Re: which way is the way to take out the bolt off the pulley crank.? (Civmochris)
what if the block is out of the car nothing attached to it and you want to get the crank out?
Old Dec 10, 2002 | 07:56 PM
D16A6Turbo's Avatar
Default Re: which way is the way to take out the bolt off the pulley crank.? (JeremyL)
Degooser is absolutely right...by far the easiest way to get that frozen bolt off is by means of taking that flywheel cover off and wedging a large screwdriver into the flywheel teeth and tranny housing. Use the screwdriver trick to also torque the crankshaft bolt down when you're done...Don't skimp on the torque when tightening it down because it will work itself right off...Degooser and I have done a roadside repair on my car because the damn thing wasn't cranked down tight enough (I used honda specs and everything)...I think my manual specs my D series to be cranked to 130lbs...We played it safe and cranked it to 150-160lbs...
good luck
Old Dec 10, 2002 | 08:04 PM
dchu's Avatar
You can try putting it in 5th gear and have a friend stand on the brakes while you work at it with a long pipe over the breaker bar.
Old Dec 11, 2002 | 02:02 PM
PupaScoopa's Avatar
Has anyone thought of using the tool that's built for this? It has a large hex outer ring that slides inside the crank pulley.
Old Dec 12, 2002 | 06:58 AM
degooser's Avatar
Default Re: which way is the way to take out the bolt off the pulley crank.? (PupaScoopa)
What does that tool look like???
because if there was a tool that would take this bolt of easier.....
sign me up!!
Old Dec 12, 2002 | 07:46 AM
turbosol's Avatar
Morrosso makes one and I'm sure Snap-on carries one too.
Old Dec 12, 2002 | 07:57 AM
HOOKUPS-PRO-CRX's Avatar
Default Re: which way is the way to take out the bolt off the pulley crank.? (turbosol)
if you are working with a DOHC then the crank pulley has a hexagon opening in the middle. snap on carries a special tool that will fit inside of the pulle to hold it from moving and also allow you to put a socket 19mm through the center. this tool is a little costly but when your friends need it you can rent it out $.
Old Dec 12, 2002 | 10:51 AM
dogpile5's Avatar
25 Year Member
works everytime for me!!
Layne Barber
Apr 17, 2015 12:38 PM
1 sLoW hAtCh
Jun 1, 2008 10:07 AM
JJ's civic
16
Jan 28, 2007 06:06 PM
88 dx
13
Aug 19, 2005 10:30 AM
BoostedED9
Jun 16, 2002 06:45 AM
