another Ls motors question
Old Dec 8, 2002 | 02:46 PM
slow hatch's Avatar
Default another Ls motors question
Do i use the wiring harness off the ls motor, or do i use the wiring harness off of the stock Dx motor, and wire in two more injectors? I have no idea so anything you have would be great.
Old Dec 8, 2002 | 02:50 PM
Ef Whore's Avatar
Default Re: another Ls motors question (88' Honda Hatch)
Listen to what im saying, convert your dx harness to an Si and then throw in a 90-91 Ls motor and the harness will be plug n' play.
Old Dec 8, 2002 | 03:03 PM
slow hatch's Avatar
Default Re: another Ls motors question (Ef *****)
thanks
Old Dec 9, 2002 | 04:41 PM
StorminMatt's Avatar
This doesn't work. The plugs to the main harness on the DX are different from the SI. The DX harness must be modified to run the motor being swapped in.
Old Dec 9, 2002 | 05:43 PM
Ben Ogle's Avatar
Default Re: another Ls motors question (StorminMatt)
It works if you use the plugs off the LS harness. I just did this. It wasnt too bad, just make sure when you are switching dist plugs to not mix up the cream wires. I did and it was a pain to find. HTH.
Ben
absinthminded
Aug 31, 2008 04:48 PM
happyabortion
Sep 17, 2006 06:43 PM
ef_Racer
May 7, 2004 11:53 AM
89-ef
Feb 25, 2004 06:42 PM
