highest quality gas and octane ?'s
Old Dec 8, 2002 | 12:58 PM
HUBB's Avatar
Default highest quality gas and octane ?'s
i would like to know what the best quality (brand) of gas to use in my rsx? what octane is the best to run the type-s with. thanks.
Old Dec 9, 2002 | 07:02 AM
JUNIOR's Avatar
Default Re: highest quality gas and octane ?'s (marinwood)
91 and up is recommanded
Old Dec 11, 2002 | 05:47 PM
phoenixR
Guest
Posts: n/a
Default Re: highest quality gas and octane ?'s (JUNIOR)
100 OCTANE!!!!!!! i can get it for 4.95 a gallon down here
Old Dec 11, 2002 | 09:25 PM
TypeR 508's Avatar
Default Re: highest quality gas and octane ?'s (phoenixR)
dayam 92 octane here for aobut 1.58 a gallon ... grr ~!!!
Old Dec 12, 2002 | 05:47 AM
F1HONDA's Avatar
Default Re: highest quality gas and octane ?'s (crashmase)
sunoco 94 if you can find it
Old Dec 12, 2002 | 06:59 AM
2k2silvertype-s's Avatar
Default Re: highest quality gas and octane ?'s (F1HONDA)
actually a local 76 station sells 102 here. good for hytechs high compression pistons
Old Dec 12, 2002 | 10:18 AM
GreenR's Avatar
Default Re: highest quality gas and octane ?'s (2k2silvertype-s)
VP Racing C-16 116 Octane $7.00/ gallon 5 gallon minimum.
Sunoco 100 Octane $3.72/ gallon.
Old Dec 13, 2002 | 06:07 PM
Mr Boston's Avatar
Default Re: highest quality gas and octane ?'s (GreenR)
Sunoco 94
Old Dec 14, 2002 | 12:45 AM
The HamsterBall's Avatar
hrm... can i say.. idiot?
as long as your car does not knock and ping.. youre fine. higher octane fuel (that is un-needed) is a foolish waste of money. because the richer mixture won't do **** for you car. just use the whatever octane gas is recommended for your RSX (i think it's 91).
Old Dec 14, 2002 | 02:56 PM
MK Ultra's Avatar
Default Re: highest quality gas and octane ?'s (HamsterBall)
You have no place calling anybody an idiot.
First of all, the K20A2 uses a knock sensor, meaning that the engine may run just fine on lower octane fuel but it will be making less power due to the ECU retarding timing.
Second, the air/fuel ratio is not affected in the least by the octane rating of gasoline. The engine will not run richer with higher octane. Octane is the measurement of the ratio of 5-ring to 6-ring hydrocarbons in the fuel. 6-ring hydrocarbons are more stable than 5-ring hydrocarbons, which means that a fuel with a higher ratio of 6-ring hydrocarbons is less prone to detonation.
Old Dec 14, 2002 | 07:00 PM
R8dR's Avatar
New User
I like texaco 91 myself. It works fine here during the 110 degree summers. I'm assuming your running a fairly stock engine in a milder climate, so I don't think you'll need octane higher than 91. You'll be wasting money buying higher octane gas.
Old Dec 14, 2002 | 07:12 PM
oldB18EF's Avatar
Default Re: highest quality gas and octane ?'s (Integra Type R)
Sunoco 94
motocross 04
Oct 19, 2004 06:02 PM
TheHater
Feb 13, 2003 04:29 PM
DR3AM
Nov 11, 2002 01:27 PM
Yellow Dragon
Jan 30, 2002 05:03 PM
