engie mount insert question?
Old Dec 8, 2002 | 12:04 PM
JICsube's Avatar
Default engie mount insert question?
ok i have the energy suspension inserts. (not installed yet) and i was hoping that these would fix my blown driver side engine mount. (its got a big rip and all the goo is gone ) someone told me i have to buy a new engine mount 1st or the insert wont last/work. is that true? thnks
Old Dec 8, 2002 | 01:04 PM
double0Si's Avatar
Default Re: engie mount insert question? (axion7606)
What car is this? I didn't realize that there was 'goo' in the mounts.
The inserts that you have are for only three out of the five engine mounts.
If one is shot, I would replace it first. IMO
Old Dec 8, 2002 | 02:14 PM
Kataku2K3's Avatar
Default Re: engie mount insert question? (double0Si)
If you are working with a DC or EG the mounts are the same.. The 94+ integra and 95 Si use the same driverside upper mount... I'm not sure about Energy but Prothanes insert replaces the whole inside.... I've put Energy's in my friend's cars before but i've never seen the upper kit for the driverside and tranny... I guess it just depends on what car and if your insert kit comes with the mount.... I personally like the Prothane kit better just cuz it's stiffer... but yea that's just my opinion... Peace
Old Dec 8, 2002 | 02:18 PM
JICsube's Avatar
Default Re: engie mount insert question? (JDMspecEG6)
my car is a 93 cx hatch with a b18c1 motor in it. the inserts are juss like little rubber things wth zip ties. thats why i was wondering if those would replace the blown stock one. or i would have too buy a whole new mount for 100.00 plus dollars
Old Dec 8, 2002 | 03:16 PM
Kataku2K3's Avatar
Your driverside upper or lower mount is ripped??? If your bottom one is ripped then it may be okay.... The vibration mounts don't do a whole hell of a lot.... If your driverside upper is ripped then you'll need to replace the mount... It would however be cheaper just to buy the Prothane insert kit which would replace the center of that mount... Again like i said before the Prothane kit is a lot more stable than the Energy... Peace
Old Dec 8, 2002 | 04:29 PM
JICsube's Avatar
it is my driver side upper, do you have any links or pics of the Prothane insert kit? maybe ill sell my energy suspension ones. and get those if that replaces my ripped mount.
Old Dec 8, 2002 | 05:04 PM
Kataku2K3's Avatar
Sorry about this pic but I used my friend's 3.3megapixel cam and it has some crazy *** resolution.... I just did this swap about a month ago for my friend "Cheddabob"... You can see the insert replaces the entire inside of the stock mount... I'll get you the link to JC Whitney where he ordered them from..
Old Dec 8, 2002 | 05:10 PM
Kataku2K3's Avatar
The engine bay and motor were kinda dirty cuz this was the day i dropped it in... The wires look a little more organized and the engine bay is a little cleaner now.. I also had the valvecover ground on the wrong point, but it's all fixed now... Here's the direct link to JC Whitney.... We need the mounts shipped like 2 day and the total was something like $85 but even if you did that it's still cheaper than payin $100 for just the mount... http://www.jcwhitney.com/item.jhtml?...=43099&BQ=jcw2 I just realized that they put the wrong picture up for the kit... don't worry tho it is the one you will want to order...
[Modified by JDMspecEG6, 6:12 PM 12/8/2002]
Old Dec 8, 2002 | 09:21 PM
JICsube's Avatar
thanks for the help, the pic from jc witney, looks like my energy suspension ones thou, except in black
Old Dec 8, 2002 | 10:11 PM
Muckman's Avatar
Moderator in Chief
I got the ES Inserts (all 3 of them) and it didnt do **** for my wheel hop. And my car still bucks at low rpm (was hoping to get rid of that nasty engine flex). All I got was a car that vibrates alot more, and crisper shifting.
Old Dec 8, 2002 | 10:59 PM
JICsube's Avatar
Default Re: engie mount insert question? (Muckman)
but did the es inserts replace the old rubber in the stock mount (i.e.-driverside upper?)? and you dont like yer new back massager?
Old Dec 9, 2002 | 04:43 AM
Ricky Rojales's Avatar
My ES were inserts. The 2 lower front and the tranny rear had the "inserts" placed into holes normally molded into the mounts. The inserts fill in the holes and make a more solid mount.
The engine mounts, left and right respectively, can be replaced completely. No inserts, just like the photo in this thread.
Old Dec 9, 2002 | 07:47 AM
Kataku2K3's Avatar
Default Re: engie mount insert question? (Ralphie)
Yea, that's what I was saying about those Energy's, I've only seen them used once and that was on my friend's LSVTEC Teg... It helped out a bit but from the time I put them in I knew that they weren't going to be as stiff... They just had a little more softer rubbery feel.... The Prothanes feel like a hard plastic... If you really wanna get rid of that motor rock and wheel hop Muckman I would just hook up some Prothanes and a traction bar... The traction bar should just about get rid of all your wheel hop alone... Peace
Old Dec 9, 2002 | 08:48 AM
Muckman's Avatar
Moderator in Chief
The inserts just fit into the hallow motor mounts like a jigsaw puzzle. It just filles up the gaps with the polyurethan insert.
I like my new back massager, im just saying it didnt do anything else but that.
Old Dec 11, 2002 | 04:25 AM
The Poopsmith's Avatar
I like my new back massager, im just saying it didnt do anything else but that. <IMG NAME="icon" SRC="http://rely.net/~htimages/smile/emthdown.gif" BORDER="0">
If you put them in a 00 GSR they wont make as much difference as replacing the old mounts from a 94 GSR
Old Dec 11, 2002 | 05:06 AM
nolimits's Avatar
You'll need a new motor mount. The prothane kit actually has 2 small tabs that fit into that top mount (you would still need a new mount), while the es doesn't cover that mount. You want to replace this! When mine broke I tried to find a heavy duty replacement, but gave up and bought the oem part. There is one available that I came accross afterwards...I think it was at http://www.placeracing.com...not sure. The "goo" is oil in a diaphram, but I couldn't tell you the theory behind that....some sort of dampener I guess.
Old Dec 11, 2002 | 05:07 AM
nolimits's Avatar
Default Re: engie mount insert question? (00turbosi)
saemoonyang
11
Nov 3, 2011 12:33 PM
dwerpk
Dec 25, 2006 11:22 PM
DB1_559
Jun 8, 2006 03:52 PM
luderchris
Jul 20, 2005 07:06 AM
TurboTagTeam
11
Dec 24, 2004 12:00 PM
