Front Speaker Wiring through door jam
My friend peeled back the rubber housing deal around the existing speaker wires going into the front doors of my 92 EX Sedan. It looks like there is a plug there so Honda could wire the door all up, (mirrors, windows, speakers) and then just "plug" it in to make everything work. I would like to run new speaker wire to my front speakers and was wondering if it's best to just drill a hole in the doors & door frame to do it (grommeted of course).
i know on mine, i just cut out the center of the plugs and ran the speaker wire through, but then again i only had speaker wires going into the door, don't know if you have more then that or not
if that is not an option, if there is enough room to drill a hole in the plastic bracket so you can still rumm the wire though the rubber sleave back into the car that would be best
*edit* reason there are soo many wires is cause you have power windows, mirros, locks, and speakers.. on a dx cx there is only speaker wire and its easier to get through
[Modified by 95CivicEX, 9:44 PM 12/9/2002]
When I ran new speaker wire in my del Sol I cut open the sleeve and slid the wire through an opening I made in the connector and seeled it up with electrical tape. Kinda ghetto, but looks decent and works.
Pull the door off and it's cake. Trust me, you will save time and frustration, and it's a lot easier than you think.
Just to let you know the way i did it was by taking the fender off and cutting a whole in the boot on the car side and by drilling a small hole just below the molex plug and then running the wire through the pipe and then through the grommet in the new hole i drilled. it works and you see no wire as long as you use as much of the existed boot that you can. i had to do this when i ran my window control module also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bikeboy80 »</TD></TR><TR><TD CLASS="quote">i know on mine, i just cut out the center of the plugs and ran the speaker wire through, but then again i only had speaker wires going into the door, don't know if you have more then that or not
I'm looking to run new wire in my 93 Cx. These plugs you have to cut out. How many are there? I should only have the OEM speaker wires to worry about. I'm going to remove the door panel and give this a try tommorrow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch »</TD></TR><TR><TD CLASS="quote">
I'm looking to run new wire in my 93 Cx. These plugs you have to cut out. How many are there? I should only have the OEM speaker wires to worry about. I'm going to remove the door panel and give this a try tommorrow.</TD></TR></TABLE>
yes you will or should only have door speaker wires in that plug.. never worked on a CX dont know if it a molex plug like everything else but im sure it is cause its a honda.. it will be a lot easier to get those wires in there on your car..
You gotta search:
https://honda-tech.com/zerothread?id=215223
It should be very easy in a car without all the power accessories....and while it was difficult, I didn't have to remove a door or a fender...I'd prefer to not mess up the alignment - it just takes some patience.
tfalconier
Apr 10, 2004 06:45 PM
