Differece between Eiback spring in GC coilovers and spring Eibach offers directly?
Old Dec 8, 2002 | 11:09 AM
Norcalstoppy's Avatar
Default Differece between Eiback spring in GC coilovers and spring Eibach offers directly?
What are the difference? Is GC one special or something. I think pretty much everyone figured out by now that skunk2 coilovers are same quality as matrix ones....so I dont' want skunk2 no more. What's up with GC?
Jay Kim
Old Dec 8, 2002 | 03:43 PM
rice a rona's Avatar
Default Re: Differece between Eiback spring in GC coilovers and spring Eibach offers directly? (AllMotorMons
There really isnt much of a difference since they are both Eibach springs in them...ones a coil over and Eibachs are just lowering springs. The only other difference might be spring rate...you would have ask GC's tech and see what the spring rate is on those. Also if you wanted, Eibach can make custom springs for the coilover if you didnt like the springs it came with.
Old Dec 8, 2002 | 07:13 PM
Then if you could get a hold of perches, couldn't you just buy eibach lowering springs and use it with those?
Jay Kim
Old Dec 8, 2002 | 10:21 PM
Muckman's Avatar
Moderator in Chief
Yes thats what alot of people do. But your oem shocks wont be able to dampen the higher spring rate and youll get a bouncy ride. Will eventually wear them out too.
Ground Control uses the same ERS springs from Eibach as you can buy from Eibach directly. However I was told from GC, the standard kit from GC uses a progressive spring rate, where as custom rates are constant rate springs.
Old Dec 9, 2002 | 04:49 AM
Ricky Rojales's Avatar
The difference is in the coil diameter, rate, and free length, as well as the seat of the coil.
Ready4lyf
Suspension & Brakes
17
Apr 23, 2011 08:37 AM
wEaK Squad *ATL*
Suspension & Brakes
Apr 25, 2010 07:32 PM
bmoua
Jul 22, 2007 05:24 PM
EeeJayEight
Suspension & Brakes
Jan 24, 2006 04:21 PM
itchy
May 31, 2002 07:08 PM
