coil over?
Old Dec 8, 2002 | 12:56 AM
iwouldHITit's Avatar
Default coil over?
are all coils basicly the same for honda? i heard that it was the same..but the only thing differnet is the spring rate.. so if put integra coilover(i.e. groundcontor) on my crx will it give me a stiffer ride?
Old Dec 8, 2002 | 10:19 AM
hybrid4dr's Avatar
Default Re: coil over? (iwouldHITit)
i think to my opinion they ride better stiffer
Old Dec 8, 2002 | 12:16 PM
Ef Whore's Avatar
what the **** is the point of that? that is why ground control has diff. spring rates, and u can buy adj. shocks and set to your desired stiffness. Buy what is meant for your car.
Old Dec 8, 2002 | 12:23 PM
neutron91's Avatar
Default Re: coil over? (Ef *****)
Old Dec 8, 2002 | 09:01 PM
NAZC's Avatar
Default Re: coil over? (neutron89)
I got 2g teg coilovers for my ef and they fit fine but yes it is stiffer
Old Dec 8, 2002 | 09:16 PM
CRX Si's Avatar
maybe he used to have a teg and still has the springs... Use your head and stop flaming people...
Old Dec 8, 2002 | 09:37 PM
travis's Avatar
Default Re: coil over? (CRX Si)
Of course, the OEM suspension on the CRX is a coilover suspension. It's just not adjustable. The term "coilover" makes no reference at all to adjustability, length, spring rates, or damping power. Those are inherent in the springs, dampers, and sleeves (or in many setups, the shock bodies themselves). What you need is the correct spring rates for your application, the right length for your car, and a damper that can control those spring rates. That's basically all there is to it, adjustable coilover or not.
Ready4lyf
Suspension & Brakes
17
Apr 23, 2011 08:37 AM
tempsohc
Suspension & Brakes
Dec 17, 2010 11:20 AM
VtecAdvantage
Mar 20, 2006 01:46 PM
G-reX
Feb 14, 2003 05:33 PM
