b16a2from 99 si into 96 civic
As far as the wiring goes,we want to be able to use the 99 si harness and the ecu...What do we need from the 99 si to be able to make this a plug and play swap into the 96 civic???
You can do it if you repin the green interior plug next to the ECU... I personally find it easier to just rework the 96 Civic's harness... The downside to this is you won't be able to run the P2T 99 Si ECU.... You'll need to either run a 96-99 GSR or get a conversion harness which would be the easiest from OBD1-OBD2... There is one last option and that is to buy or make a OBD2b to OBD2a harness, then you can run the 99 Si ECU.. Hope this helps...
hey thanks,looks like we just went ahead and used the ex harness...the owner had a 96 gsr computer afterall...Worked out good so far.
gsr95jacob
13
Apr 25, 2011 09:20 PM
