88-91 Civic/CRX FD Question
Old Dec 7, 2002 | 04:05 PM
SMSP's Avatar
Default 88-91 Civic/CRX FD Question
Do any of the 5 sp FDs fit in the 4sp manual of the Civic Std?
Also, what's a good site to find all the tranny ratios for the 88-91 Civics? Thanks.
Old Dec 7, 2002 | 04:07 PM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Re: 88-91 Civic/CRX FD Question (SMSP)
I shouold be taking out my dx motor and 5spd tranny and droppiong it the 90 dx hatchback that came with only 4spd.
Old Dec 7, 2002 | 04:12 PM
SMSP's Avatar
Default Re: 88-91 Civic/CRX FD Question (Civicdrgrcr)
I'm keeping the 4sp but looking for a shorter final drive and was hoping one of the 5sp FDs could be used??????
Old Dec 7, 2002 | 07:36 PM
USDM 4G VTEC's Avatar
stay away from the 4 speed..
i have one and its something u need to avoid ASAP... when i swaped the 4 speed for the Si one i was happy as ****... u have no idea how much powe ru loosing ! beleive me pick a Si tranny and ull be set
Old Dec 7, 2002 | 08:32 PM
whizdumb's Avatar
Default Re: 88-91 Civic/CRX FD Question (JDM EF9)
4G 88-91 USDM
HF DX Si ZC
1st 3.250 3.250 3.250 3.250
2nd 1.650 1.894 1.894 1.944
3rd 1.033 1.259 1.259 1.346
4th 0.823 0.937 0.937 1.033
5th 0.694 0.771 0.771 0.878
REVERSE 3.153 3.153 3.153 3.153
FINAL 3.888 4.250 3.933 3.88
Fastest stock = Si
Fastest hybrid = ZC w/ Si Final
5G 92-95 USDM
EX/Si
1st-----3.250
2nd-----1.900
3rd-----1.250
4th-----0.909
5th-----0.750 for Si HB and Del sol Si
or------0.702 for 2 dr or 4 dr sedan
Final Drive---4.250
DX
1st-----3.250
2nd-----1.762
3rd-----1.172
4th-----0.909
5th-----0.702
Final Drive---4.058
CX and VX
1st-----3.250
2nd-----1.761
3rd-----1.066
4th-----0.853
5th-----0.702
Final Drive---3.250
That is what I have found, I think most of it is thanks to Mista Bone.
Old Dec 8, 2002 | 05:37 PM
keithv's Avatar
dave, check you IMs.
Old Dec 8, 2002 | 06:28 PM
SMSP's Avatar
I must for the class (SCCA ITC).
Maybe the Si 4.25 will fit?????????
Old Dec 9, 2002 | 04:36 AM
Mista Bone's Avatar
D Tranny Guru
Dave, as long as you use the ring gear and matched countershaft, any of the L3 FD ratios will fit. Don't change the diff, just the ring gear that way you won't have reshim the diff.
2.93, 3.25 (what you have now), 3.889, 4.058, 4.250, 4.437 (Rover) 4.73 are the ratios that are available.
You could get a 4.73 from OPM or Houseman. Jamie can make you a 5.00, if you have the $$$$.
I've not read the GCR rules for IT classes.
dpfi_1.6EFktr
13
Sep 20, 2007 12:24 PM
Tuner Eddy
20
Jan 28, 2007 02:47 PM
DB'd
Oct 11, 2004 05:09 PM
julio_bOostamante
Mar 19, 2004 07:02 PM
allmotorEG-SI
Apr 1, 2002 03:51 AM
