Tool for adjusting VTEC head valves
Old Dec 7, 2002 | 02:21 PM
7rrivera7's Avatar
Default Tool for adjusting VTEC head valves
My mechanic says there is a tool made specifically for adjusting VTEC valves. Can someone tell me if they have seen this and who makes it?
Thanks!
Old Dec 7, 2002 | 02:22 PM
Desslok's Avatar
Default Re: Tool for adjusting VTEC head valves (7rrivera7)
I know SNap On makes one, but pricey.
Old Dec 7, 2002 | 03:33 PM
Kataku2K3's Avatar
Default Re: Tool for adjusting VTEC head valves (sp)
You can just bend a open end 10mm like this and it will work fine... I've also done it without the tool but it takes time to get the feel.... With out the tool i just use a deep 10mm socket, set the set screw so there is a little extra lash then tighten the 10mm expecting it to slip a little.. Of course you have to double check and that's what takes time... I really would like a snap on tool but for now i'm fine with my little Craftsman crows foot that i just got the other day... It seems to work fine... here's a pic of how to bend the open end if you decide you would to do it... Besides it's the cheapest...
If you don't wanna go through the work of making it there are a few people on here that make them... I've seen them say that all you are payin for is the wrench and shipping so they really aren't makin anything profit... I dunno tho...
Old Dec 7, 2002 | 03:54 PM
slow02ss camaro's Avatar
Its like $45 shipped from snap-on...its worth the money....ease of adjustment and you can be more accurate than a closed socket wrench, b/c with a closed socket you just hope you don't keep turning the adjustment as you tighten the bolt.
Old Dec 7, 2002 | 03:57 PM
Desslok's Avatar
Default Re: Tool for adjusting VTEC head valves (slow94accord)
Do you have a link for that, cause I asked a dealer in his truck and I thought he said about $160. If its only 45 I'll buy one today.
Old Dec 7, 2002 | 04:03 PM
Kataku2K3's Avatar
Yea if they're that cheap I would just buy a real one too.. Thanks... I always heard that they were kinda pricey but that's not bad at all..
Old Dec 7, 2002 | 07:39 PM
94TealGSR's Avatar
http://buy.snapon.com/catalog/pro_de...re&dir=catalog
Try that link, see if it works. If not, go to http://www.SnapOn.com and browse the catalog under "Valve". You want the 10mm.
Old Dec 7, 2002 | 07:47 PM
Kataku2K3's Avatar
Default Re: Tool for adjusting VTEC head valves (94TealGSR)
Yea, that's the **** i want...
Old Dec 7, 2002 | 09:29 PM
Desslok's Avatar
Cool, thanks for the link. I'm ordering now.
Old Dec 7, 2002 | 10:34 PM
sirminder's Avatar
Default Re: Tool for adjusting VTEC head valves (JDMspecEG6)
Can you or anyone else please tell me how to make this. Or who exactly makes them. I know $45 might not be that much to pay for a handy tool, but if thing open wrench tool also does the job, then ill like to have this. thanx.
Old Dec 7, 2002 | 11:02 PM
Nameless RB26's Avatar
Default Re: Tool for adjusting VTEC head valves (sirminder)
I made one of those do-it-yourself valve adjustment wrenches like above.
What a ****** waste. The metal had weakened so bad after I heated it that it ended up bending to where I couldn't use it. I would suggest NOT doing that and buying the snap-on
Old Dec 7, 2002 | 11:03 PM
Kataku2K3's Avatar
Just clamp a 10mm open end into a vise and heat it up with a torch.... You can get it hot enough to were you can just bend it by lightly tapping it with a hammer... The end on the left is the one that you wanna copy... cuz you will want to bend it pretty close to the head of the wrench so that it will fit into the tight little spots... If i can find the guy that was sellin them on here i'll get it to you... Lemme know if you need anymore help.... Peace
Old Dec 8, 2002 | 05:20 AM
t0p_sh0tta's Avatar
I while back, I brought the same thing from Harborfreight.com, but it came with 4 different sized adj. tools, and its was only $30 something?
Old Dec 8, 2002 | 06:45 AM
bruthaboost's Avatar
Default Re: Tool for adjusting VTEC head valves (REVOEVOM)
Got mine from the same place. Looks just like the snap on and it was 18.00 shipped.
Old Dec 8, 2002 | 02:02 PM
sirminder's Avatar
Default Re: Tool for adjusting VTEC head valves (bruthaboost)
from harborfreight u say? ill make a stop there and check...its called a valve adjustment wrench right.
Old Dec 8, 2002 | 03:33 PM
get wet racing's Avatar
I have an 89 b16 jdm, Can one of you guys give me a sit or something to show how to adjust vavles please. thanks.
Old Dec 8, 2002 | 03:41 PM
Kataku2K3's Avatar
Default Re: Tool for adjusting VTEC head valves (get wet racing)
Check out C-Speed's site... It's got some pretty detailed info that should help you... Good Luck http://www.c-speedracing.com/howto/v...alveadjust.php
thecorey
Sep 26, 2009 04:58 PM
egizzle8
Dec 13, 2004 06:23 AM
dohcter g
Nov 8, 2003 04:32 PM
ludesleep
Jun 18, 2003 06:14 AM
BrandonClaps
Apr 14, 2003 07:23 AM
