Y8 swap A/C?
Old Dec 7, 2002 | 11:47 AM
FR-MOB: ThE bEe GuY's Avatar
Default Y8 swap A/C?
Im planning to get a Y8 swap into my 90 CRX in the future, jus wondering if all my A/C stuff will bolt on and work with it? I did a search on it but didnt find anything
Old Dec 7, 2002 | 12:03 PM
Mefain's Avatar
Default Re: Y8 swap A/C? (hondaspeed85)
to be honest with you man....you could live w.out the AC...ive been told it alone is between 30 and 40lbs of extra weight....but a Y8 is a d-series motor...why wouldnt it fit into a motor bay that will hold a b16 and A/C....but i have a Y8 swap...No A/C cause i have a DX model CRX...but i enjoy the swap and you should to
Old Dec 7, 2002 | 12:40 PM
Default Re: Y8 swap A/C? (NjoySleepn)
No, hell no i cant live without A/C, lol. When i had my 89 with no A/C, i wanted to die in the summer here in cali. I dont mind the extra weight, i'd rather have the extra weight than sweat to death. But good, i get to keep my a/c
Old Dec 8, 2002 | 04:01 PM
cbrman's Avatar
you will have to use your a6 compressor mounting bracket. The y8 mounting bracket will not bolt up with your a6 compressor.
I have the a6 compressor/a6 compressor bracket bolted to the y8 block.
If you were goint to use the y8 compressor, then you would have to use the y8 compressor mounting bracket.
The 4 bolts that hold the compressor bracket to the block are the same, but the 4 bolts that hold the compressor to the compressor bracket are different from the a6 and the y8.
I wanted to use the y8 compressor bracket because it is aluminum and it is a little lighter than the a6 one, but it wouldnt work.
Steven
[Modified by cbrman, 1:09 AM 12/9/2002]
Benny Burk
May 19, 2015 05:44 PM
Project Dad
Apr 15, 2011 10:03 AM
EJ8-y8
Apr 9, 2006 03:50 PM
primo97
Feb 22, 2006 10:48 AM
VTgringo
Mar 11, 2004 05:13 PM
