MORE rear disc swap questions.
Old Dec 7, 2002 | 09:38 AM
ex voto's Avatar
Default MORE rear disc swap questions.
Aight... I have the rear arms, calipers, rotors and all for the swap, and I'm getting ready to do the actual change over.
I went ahead and bought Integra four door parking brake cables so I can get the length right. The question is, does anyone know that these will work? I'm kind of hoping that they will... obviously.
Old Dec 7, 2002 | 10:03 AM
FourthGenHatch's Avatar
Default Re: MORE rear disc swap questions. (ex voto)
I always thought only Coupe would work for Civic Hatch/CRX, unless maybe you have a Sedan Civic?
Old Dec 7, 2002 | 10:11 AM
ex voto's Avatar
Default Re: MORE rear disc swap questions. (FourthGenHatch)
Yep. All EXs in '91 were sedans. Silly little car.
Old Dec 7, 2002 | 10:23 AM
zCivic's Avatar
That is a good question. Is the wheel base any different between H/B and Sedans?? If not you need most likly the 2 door cables. I've looked a http://www.hondaautomotiveparts.com/ and
http://www.acuraautomotiveparts.net/ cann't even find e-brake cables. Was tring to tell difference between DX H/B and EX Sedans, then 2 Door Tegs and 4 door Tegs. I could suggest checking with Napa and see if there listed as the same p/n.
Old Dec 7, 2002 | 12:04 PM
d357r0y's Avatar
i just did this.. you need 2 (two) door e-brake cables.
black0hatch
May 15, 2009 03:51 PM
djrico724
Feb 9, 2009 06:31 AM
Loaded Butane
Apr 19, 2007 01:50 PM
schpootypie
Jan 3, 2006 07:36 PM
