disc. conversion-help
i have just acquired 91 DA trailing arms w/ the cables. I am going to put on my hatch monday, but i am not changing master cylinders. 2 questions- Will they still work well w/out changing the cylinders?--Will my drum brake fluid lines work or should i grab those too? Thanx.
yes.. u can use existing brake line.. but for Ebrake.. u will have to pull it off from the integra also.. well thats what i had to do .. other than that i didnt change anything .. Re bleed the brakes and ur done.. .. take a look at my page below.. i have my recent Conversion on there
Ebrake cables from a teg will work, year doesn't matter, now the brake lines will not work you need brake lines for either a 90-00 CR-X/Civic w/rear disc brakes , or a 90-00 Integra. I used the same (factory equipment) M-C on 4 swaps I've done, 2 of my own, I just used the same M-C and P-P Valve
[Modified by zCivic, 11:08 AM 12/7/2002]
GeoMetry
Nov 11, 2015 09:20 AM
sohctodohc
Apr 15, 2006 01:06 AM
JDM_EK_JOE
Mar 30, 2006 09:43 PM
