T3/T4 Ebay Rebuild Kit... Worth it or No? Link provided.
Old Dec 7, 2002 | 07:24 AM
Sirex's Avatar
Default T3/T4 Ebay Rebuild Kit... Worth it or No? Link provided.
Well i have a damaged T3 Turbo and i was wondering if anyone had any info on these rebuild kits on ebay for 60 bucks..
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1874367264
Worth it or no?
Old Dec 7, 2002 | 08:38 AM
Sirex's Avatar
Default Re: T3/T4 Ebay Rebuild Kit... Worth it or No? Link provided. (Sirex)
Old Dec 7, 2002 | 12:06 PM
inspyral's Avatar
I'd like to know as well. Although, I don't see how you would be able to balance the shaft yourself, after replacing all the seals and whatnot...
Old Dec 7, 2002 | 12:30 PM
rioninja's Avatar
Default Re: T3/T4 Ebay Rebuild Kit... Worth it or No? Link provided. (inspyral)
You really wont need to balance the shaft, as long as you mark the compressor wheel and replace it exactly as it came off. The seals and such wont affect the balance.
Old Dec 7, 2002 | 12:35 PM
BudaKai's Avatar
Default Re: T3/T4 Ebay Rebuild Kit... Worth it or No? Link provided. (RioNinja)
The rebuild is for a T3/T4 hybrid not a normal T3. You'll only have the right seals for the turbine side; the compressor seals will be too small. It is a hell of a price compared to the $240 Garrett is asking for the new kits.
Old Dec 7, 2002 | 12:57 PM
inspyral's Avatar
Default Re: T3/T4 Ebay Rebuild Kit... Worth it or No? Link provided. (tzsir)
I think it says the kits ar for T3 OR T4 turbos, which I take to mean he has kits for T3's and kits for T4's. Now I'm wondering which one will work for my T3/T04B...
Old Dec 7, 2002 | 01:44 PM
BudaKai's Avatar
That's a good question please Im me or something when you find out as I am curious as well on this topic. It still seems like it's for the hybrid to me though because the T3 and T4 don't share a single seal or ring from what I can tell from mine.
Old Dec 7, 2002 | 02:27 PM
filetofit
Guest
Posts: n/a
I did my turbonetics t3/t4b with a kit from same. $85, came with seals, bearings, rings and then another $35 or so to have it balanced. Like a previous poster said, I probably could have skipped the rebalance by marking the compressor wheel.
Old Dec 7, 2002 | 02:45 PM
civictypenos's Avatar
Default Re: T3/T4 Ebay Rebuild Kit... Worth it or No? Link provided. (filetofit)
where did you get your kit from?
Old Dec 7, 2002 | 06:19 PM
filetofit
Guest
Posts: n/a
Default Re: T3/T4 Ebay Rebuild Kit... Worth it or No? Link provided. (civictypenos)
Got it from turbonetics.
http://www.turboneticsinc.com
Sometimes they'll say they don't sell to individuals and refer you to a dealer. They don't consistently maintain that policy though for some reason.
Old Dec 7, 2002 | 06:26 PM
cock head's Avatar
What would happen if you take off the compressor wheel without marking it and them put it on after rebuilding the turbo?
Old Dec 7, 2002 | 06:45 PM
filetofit
Guest
Posts: n/a
Default Re: T3/T4 Ebay Rebuild Kit... Worth it or No? Link provided. (therumblingteg)
The thing spins pretty damn fast so an imbalance is going to make it vibrate acclerating wear and tear. Ever had a tire that was out of balance because you put a can of fix-a-flat in it. It's fine on the street but take it on the highway and about 70 that thing will start to shake the steering wheel. Same principle.
Old Dec 7, 2002 | 07:48 PM
Sirex's Avatar
Thanks for all the input guys.. i might give this a world.. im on a pretty right budget here and one of my main expensive pieces will be the zdyne silver ecu with the injectors.. i want my fuel management to be very stable and overall best performance so i might as well dish out the cash so i can at least run 10psi on the stock internals.. i mean i love hacks and riggs but with this im pretty confertable going upto 10psi rather than 6 to 8 psi... i can run 8psi dailey and 10 at the track
Old Dec 7, 2002 | 08:21 PM
cock head's Avatar
__________________________________________________ _________________
That makes sence but why does it matter if the propeller goes on different, just want to know thanks.
Old Dec 8, 2002 | 06:18 AM
because it will shift weight to the other side of the shaft,they are balanced by grinding down material to make it the same weight ,if you put the wheel back on the wrong way the weight will be shifted,you will go through bearings fast possably end up hitting the housing with it.
mackinit
Feb 25, 2011 01:09 PM
Franshow
Jul 26, 2010 10:23 AM
xsenceo89x
Northeast (Sales)
Apr 17, 2008 08:39 AM
boosted_zc
Aug 1, 2006 04:31 PM
PhantomX
Feb 13, 2006 12:52 AM
