am i launching too low?
Old Dec 7, 2002 | 02:07 AM
kHoA DoGG's Avatar
Default am i launching too low?
i had some crappy pirelli tires on my 14's and launch with msd 2step at 3k. b16a with bolt ons in a crx. i always lose first gear than catch up in the other gears. vtec at 5100 and turns off at 4200 with vafc. tonite at the street races (just went to watch, left my car at home) i noticed people launching near 5k rpm and redlining with dohc vtec motors in coupes. is THAT the proper way to launch? one guy right when he popped the clutch engaged vtec! now i have 205/50/15 falken azenis. should i use a diff launch pill? or should i continue with the 3k launch?
Old Dec 7, 2002 | 02:28 AM
tnbigdawg's Avatar
Default Re: am i launching too low? (sNoOzin' EF8)
I launch at around 5K......I ran a 14.8 1/4mile when I had a bone stock b16a2 in my 98 civic coupe....Si/r's in my area run 15.7's with all bolt-ons and cams!
so practice at different RPM's to find your "sweet spot" cause every bit counts with a low torque b16.
goodluck
Old Dec 7, 2002 | 06:51 AM
SupaTegRS's Avatar
Default Re: am i launching too low? (tnbigdawg)
ok, this may be a dumb question, but if you launch at 5k, how do you keep from spinning out like a ****??? Just feather the throttle?
Old Dec 7, 2002 | 08:37 AM
crx(gator)'s Avatar
i would slip the clutch at 4500-5000 on my d16a6 with stock clutch...
Old Dec 7, 2002 | 10:17 AM
kHoA DoGG's Avatar
Default Re: am i launching too low? (crxgator)
wat do you mean slip the clutch? and should i not use my msd 2step so i can feather the clutch?
Old Dec 7, 2002 | 10:19 AM
tnbigdawg's Avatar
Default Re: am i launching too low? (SupaTegRS)
with the right PSI's (15-22) on the tires, you can get just a little slippage at first, but right at the end of 1'st gear it hooked right up and slammed me into my seat! Again, this was at the racetrack with my old stock b16a2 motor and this thing had little torque.
Old Dec 7, 2002 | 11:01 AM
kHoA DoGG's Avatar
yeah, i figured a little wheelspin is good, just a little so it doesn't bog. but then you see the FR and MR cars that hook right up.
Old Dec 7, 2002 | 01:10 PM
crx(gator)'s Avatar
slipping=featering...i never lower my tire pressure at the track...i want my car the same way like its on the street, that way you get an acurate time...i also used 185/60/14 goodyear eagle hp's...i guess i learned how to launch after time, because i really dont peel out...all i can say is practice, practice, practice...
dc2Rgirl
May 20, 2004 02:13 AM
desert eagle
May 8, 2004 11:12 AM
Kermit EK
Aug 20, 2002 11:07 PM
HoNdAcRx88
Jun 26, 2002 05:31 PM
