ACT clutches - Heavy Duty vs Xtreme Pressure plates
Old Dec 7, 2002 | 12:53 AM
Evolsport's Avatar
Default ACT clutches - Heavy Duty vs Xtreme Pressure plates
I was just wondering if there is a big difference in pedal pressure between these two pressure plates?
Thanks!
Old Dec 7, 2002 | 05:06 AM
HotRodTeg's Avatar
Default Re: ACT clutches - Heavy Duty vs Xtreme Pressure plates (Evolsport)
The pedal pressure is just noticeable its not like alot stiffer its just stiffer. I like the heavy duty pressure plates just cause i always have been using them. For all my friends car they have best luck with these ones. Wear down less throwout bearings.
Old Dec 7, 2002 | 03:23 PM
Kataku2K3's Avatar
Default Re: ACT clutches - Heavy Duty vs Xtreme Pressure plates (streetracer)
Again I agree with ya Scott... The ACT Xtreme and Maxx Xtreme clutches both have a heavier petal than the HD which is capable of holding more but over time it is just extra wear on your throw out bearing and thrust washers.. Peace
Old Dec 8, 2002 | 08:56 AM
333's Avatar
333
Default Re: ACT clutches - Heavy Duty vs Xtreme Pressure plates (JDMspecEG6)
I have the extreme pressure plate with 6 puck. Not bad when driving but terrible when on a hill or taking off. Thought it was the six puck disc but its not it the pressure plate. I know this because I did a swap using a 4 puck and extreme plate on a stock b16a1 with Hasport mounts. He complained horrably. So, he bought the stosk steet disc same plate because he did not want to buy another kit because he could not return it. But put it back together and he still complaned about shaking a take off. Plus both were cable clutches and both hard to push down. But mine is on a turbo car, his is not. I told him just to get a stock clutch for smoothness plus it should hold about 200wh.
Old Dec 8, 2002 | 09:42 AM
IN VTEC's Avatar
I've got a HD PP and I've driven on another car with the XT PP. The pedal weight is about twice as heavy compared to stock.
The Xtreme PP is easily twice as heavy as the HD, and both grab with a lot more intensity and suddenness compared to the stock PP.
For me, the XT PP is unstreetable b/c my clutch leg would get worn out, especially in a little town with more stops.
However, there are times when I feel like the HDSS isn't enough and I want something that won't fatigue so quickly.
Old Dec 8, 2002 | 10:27 AM
Michael Delaney's Avatar
stock ITR GSR PP clamping force 1200 lb.
ACT Heavy Duty PP 1600 lb.
ACT Xtreme PP 2100 lb.
ACT MaXX Xtreme 2600 lb.
Info Source: Directly from Mr. Dirk Starksen, President of ACT to me
http://www.team-integra.net/forum/di...1&ThreadPage=1
cheers
BoOsTiN Dc2
Apr 2, 2006 02:29 PM
