91 crx si tranny 93 d16z6 what clutch?
you can use either just use the same clutch/pressure plate/flywheel.
actually i think it only applies to 89s because i think 90-00 is all the same.
use the 93 SI one..
its bigger than the 4G clitches and hold more PSI than the stock 4G one.. i think goes for like 950 psi
Can you use a 93 Si on just a 91 Si motor (D16A6)? So basically I am asking if I can get the flywheel and clutch from a 93 Si and put it into my 91 Si? Or do I need the bottom end from a Z6/Y8?
pinecone
Jun 22, 2006 05:27 PM
CvccMugen
15
Jan 15, 2006 04:27 PM
