Apexi v-afc question
Ok I have a 91 Civic with a 94 Cvic SOHC vtec engine in it. The problem is my computer is out of a non-vtec and my vtec was ran to my tach, how can I run my Apexi V-AFC to my car now. I was told that I can't run the wire straigt from Vtec to the VAFC. any ideas? thanks
yes you can. Here is the wiring Diagram link for you http://www.geocities.com/motorcity/s...tec_cont3.html
Just take the wire you have ran to the V-tec silonoid and splice it to the AFC.Presto V-tec also to set it use the VTO settings. Dont worry about the V-tec correction setting just get you low cam/high cam setting correct and that should be it. Enjoy I have....
Wet Nudl
Feb 25, 2002 01:46 PM
