fixing a smokey accord :|
Old Dec 6, 2002 | 03:52 PM
jstyle711's Avatar
Default fixing a smokey accord :|
have a 86 lx-i f/i ... its been sitting in my driveway for the past 3 months .. i decided that i wanted it, bad thing that.. blue smoke from the exhaust keeps on coming out when the car is cold, after a while the smoke starts to die down.. but its still there.. stinks =| ... and it cant pass deq also..
ive changed the oil checked spark plugs replaced the o2 sensors and had a shop repair a vaccume leak... what else is there ;|... IT STILL SMOKES!!.. .. i want to drive that car so bad =|... so whats the problem?.. thanks guys!
Old Dec 6, 2002 | 04:08 PM
RotaryBzzz's Avatar
Default Re: fixing a smokey accord :| (jstyle711)
Your engine is burning oil. Oil blow-by in the cylinders....piston rings are prolly worn out. Try a thicker oil like 20-50w.
Also ask the guy at the auto-parts store what other things (additives) would reduce the smoke.
.02
[Modified by RotaryBzzz, 5:15 PM 12/6/2002]
Old Dec 7, 2002 | 09:15 PM
SOHCMAN's Avatar
Default Re: fixing a smokey accord :| (RotaryBzzz)
dont use the additives, waste of money and the smole will come back, it just sounds like you need a good ol re-build. No snake oil/smoke stopper is going to fix that.
the 20W might be a smart move though, at least until you get it rebuilt...
cheers
Old Dec 7, 2002 | 09:28 PM
Desslok's Avatar
Default Re: fixing a smokey accord :| (SOHCMAN)
do a compression and cylinder leak test.
Old Dec 8, 2002 | 11:29 AM
Razor's Avatar
dont rebuild, with the same money you can drop in a B18C1 with no problems.
Old Dec 8, 2002 | 04:31 PM
Ludehrt's Avatar
Default Re: fixing a smokey accord :| (sp)
Yup, get yourself a compression tester. Sounds like you might have bad rings.
You can probably pick up a freasher A20 for the much less than it would cost to rebuild your current block
Old Dec 8, 2002 | 04:38 PM
niedejb's Avatar
This was brought up in the FI forum.....
Alemite CD-2 Oil Burning Formula
https://honda-tech.com/zerothread?id=347130
MartyA75074
Sep 13, 2010 11:39 AM
emosun
Feb 26, 2010 05:29 AM
924doorEG
31
Jan 8, 2008 12:25 AM
Hans5849
Jun 10, 2005 05:24 AM
redteg1
Oct 27, 2002 09:36 PM
