I need some help...
Old Dec 6, 2002 | 01:31 PM
mOBILE_iNFANTRY's Avatar
Default I need some help...
Does anyone know where the fuel pump relay is on a 91 dx hatch?
Old Dec 6, 2002 | 01:48 PM
Riceburner247's Avatar
Default Re: I need some help... (mOBILE_iNFANTRY)
i myself have a 91 DX. I checked my chilton's manual (you need to buy one also) and the only relay i could find as far as fuel in general was a main relay located under the dash (Pg. 5-17). look under the far driver's side of your dash behind the fuse box. this relay controls the power for the pump and power supply. should be a good sized plastic box. other than that, the manual doesn't really describe it or explain how to test it. good luck man, go buy a manual. I have three different kinds myself. that way if one book doesn't answer your question, chances are, the other two will.
Old Dec 6, 2002 | 02:09 PM
Default Re: I need some help... (riceburner247)
Thanks I will go get one.
Dragger817
Feb 13, 2007 02:43 PM
garageEF
Aug 9, 2006 09:39 AM
accord1987dx
Apr 12, 2004 10:14 PM
Oilman
Aug 18, 2003 08:38 PM
rice4life
Jan 10, 2003 12:02 PM
