98-00 ITR Front Lip Install Instructions
Old Dec 6, 2002 | 01:08 PM
integranator's Avatar
Default 98-00 ITR Front Lip Install Instructions
Hey, as you all know I have my itr lip, but i don't have any instructions on how to put it on. Do any of you have the actual directions on how to install this ?
Old Dec 6, 2002 | 01:56 PM
B00ST2nR's Avatar
Default Re: 98-00 ITR Front Lip Install Instructions (integranator)
its REALLLLLY easy. Especially the Front Lip. It's pretty self-explanatory if you look at your lip and the underside of your car (mouth). Do you have the screws? Well basically, all you do is put it on and screw them in.
Old Dec 6, 2002 | 02:19 PM
tC_Dragon's Avatar
Default Re: 98-00 ITR Front Lip Install Instructions (Skunk2nR)
Ok, i took a look at the OEM itr lip and OEM front bumper that is sitting in my living room right now to refresh my memory here goes:
1) 6 clips that have a nut welded onto it is wedged into 6 preexisting slots on the bottom of the front bumper.
2) obviously 6 bolts will connect the lip to those nuts from the bottom.
3) 2 holes must be drilled or made with a self tapping screw to accommodate two more screws or bolts(cant remember)
4) 2 or 4 self tapping screws in the wheel well area.
But if you would like illustrations, your local dealership may be able to print one out for you if you ask.
Eric.
Hope that helps
Old Dec 8, 2002 | 09:05 PM
Default Re: 98-00 ITR Front Lip Install Instructions (pdcdragon)
Ok, This helps me, but if any one has a more detailed explanation of how to do this, i would greatly appreciate it-- also there are two wellnuts(sp) included with the package..what do i do with these little rubber thingies?
Old Dec 8, 2002 | 10:57 PM
integobsession's Avatar
pdc dragon actually took a look at my lip and front bumper. But if you wanted more detailed instructions... then get your *** to an acura dealership. When I purchased my OEM kit a few months ago, I asked for instructions and the dude printed it out from his computer. Just ask the guy @ sales and if he's cool he'll help you out...
Old Dec 9, 2002 | 06:47 AM
Default Re: 98-00 ITR Front Lip Install Instructions (integobsession)
Cool, thnx man.
Samuels
May 11, 2008 11:28 AM
sittingonROTAS
Sep 17, 2005 07:11 PM
stumpyf4
Jan 7, 2004 07:06 PM
lessthndan
Oct 8, 2002 08:27 PM
rsx03
Feb 5, 2002 05:32 PM
