b16 - CRX - radiator hose ?
Old Dec 6, 2002 | 01:00 PM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Default b16 - CRX - radiator hose ?
I know the proper one to use is a 92 gsr lower, but im wondering if anyone has used a 90-93 LS lower instead. Reason being is that Im going to order a set of Samco hoses and they will not seperate the sets. Has anyone done that before, or could confidently say it would work if i ordered a set of 90-93 integra ls hoses?
TIA
-Todd
Old Dec 6, 2002 | 01:07 PM
DynamiteSJ's Avatar
Default Re: b16 - CRX - radiator hose ? (Count Blah)
lower hose will fit like a charm.. but the upper hose will NOT fit... you would have to cut the upper hose back about 1-2 inches for it to fit.
Old Dec 6, 2002 | 01:16 PM
Count Blah's Avatar
Default Re: b16 - CRX - radiator hose ? (DynamiteSJ)
Thanks dude...im a stupid ***, i mixed the 2 around and then to top it off i just checked Hasport and they now list the 90-91 integra upper as being able to work.
Thanks!
-Todd
Old Dec 6, 2002 | 05:29 PM
Sgt_Ox's Avatar
get the 94-95 Del Sol DOHC upper hose (do not get the 96+ they're different) fits perfect no cutting required.
Old May 8, 2004 | 08:06 PM
incubus's Avatar
ok, so lemme get this straight...
u need to use a 94-95 del sol vtec upper hose and
a 90-93 Ls lower hose?
Old May 8, 2004 | 09:02 PM
DC 2's Avatar
Default Re: b16 - CRX - radiator hose ? (incubus)
I used my stock hoses, just put something in there to strech it out, use a lighter to heat it up. Its a bitch but It aint never gonna leak! the stock hoses are 28mm, your outlet on the B is 32mm. They will fit if you want them too
efrex
Feb 10, 2006 01:40 PM
CRXified
10
Apr 26, 2005 06:54 PM
c_buz
10
Dec 21, 2004 07:21 AM
GSRCRXsi
12
Nov 16, 2004 10:36 PM
type Gendy
Mar 3, 2003 04:39 PM
