Installing HID Kit Today
Ok.....I got my kit in from Trevor
I got the (2) 20 AMP fuses....and i all ready to plug and play!!do i need some sort of gloves just in case my fingers touch the glass.......Did you guys use any gloves?
[Modified by DarkBeat, 7:26 PM 12/6/2002]
don't touch the glass....be carefull and it should not be a problem....if you do touch the glass make sure you get any foriegn matter off of the bulb....try using isopropyl alcohol and a lint free soft cloth.
Even the oils from your fingerprints on the glass of the bulb will cause it to burn out, so make sure it is clean.
[Modified by ITR-01-0977, 12:31 PM 12/6/2002]
hey i ordered hella hid kits and it didn't come with fuses. do i need to replace the fuses?
