sound deadening
Old Dec 6, 2002 | 10:23 AM
ketchup_gsr's Avatar
Default sound deadening
what's the best for insulation of road noise? I don't care about the weight too much... within reason. I hear dynomat a lot... but i just learned it's more for vibration dampening. I'm talking about road noise, engine noise... etc. Thanks
Old Dec 6, 2002 | 11:33 AM
TimeRacer's Avatar
Default Re: sound deadening (ketchup_gsr)
The only true method to do this is closed cell foam with some kind of heavy core barrier. This stuff is generally fairly expensive and you're going to have to use quite a bit since road noise is from everywhere. If you do this, try around the wheel wells (incide the cabin) first and work your way from there.
Old Dec 6, 2002 | 02:32 PM
user 9782082308's Avatar
Default Re: sound deadening (TimeRacer)
Jute (sp?)
Old Dec 6, 2002 | 03:19 PM
rybred's Avatar
any of those damping mats you use would also reduce road noise alot! U just got to put it in the right places!
Old Dec 6, 2002 | 07:27 PM
vehic_illu's Avatar
hey man, dynamat works real well for blockng road noise. Let me know if you need some for cheap. see below
Old Dec 7, 2002 | 01:50 PM
noel's Avatar
Default Re: sound deadening (vehic_illu)
You should check out Rammat. It's a helluva lot cheaper than Dynamat if you can't get a good price on the real stuff. I think it works just as well for the $.
-Noel
Old Dec 9, 2002 | 07:34 AM
vehic_illu's Avatar
Default Re: sound deadening (noel)
Whats that stuff? where you get it from? Grace Ice and water shield from the Home Depot works well too and yeah, its cheap
Old Dec 9, 2002 | 10:30 AM
Daemione's Avatar
Like TimeRacer said, the best way to reduce road noise is to use a closed cell foam. Dynamat (or a generic equivalent) will help some, but it's primary purpose is to damp vibration, not reduce road noise.
Check out www.b-quiet.com - their V/Lcomp products. It's a 1/2 inch thick, weighs about a pound per square foot, and costs $3.70 to $8.13 a square foot (depending on quantity & type).
Old Dec 9, 2002 | 10:32 AM
Default Re: sound deadening (Daemione)
hey do you think that stuff from B-quiet (the V or Lcomp) will fit in honda doors and the floors? It's pretty thick.
Old Dec 9, 2002 | 03:54 PM
smslude's Avatar
You might be able to get some sort of insultaion froma car audio store.
Old Dec 9, 2002 | 11:54 PM
Dj Lotte's Avatar
Default Re: sound deadening (smslude)
just gtake everything out of the car and take it somewhere to get Rhino or a similar product sprayed on it...
HondaScott
Honda Civic (2001 - 2005)
Oct 25, 2006 11:48 PM
Outrun
13
Jul 16, 2004 05:50 PM
jazz215
Jan 27, 2004 08:28 PM
5thGhB
Audio / Security / Video
Dec 2, 2003 08:59 PM
ketchup_gsr
22
Dec 16, 2002 03:41 PM
