LS rods in sohc, need some help
Old Dec 5, 2002 | 11:58 PM
Timmayeg's Avatar
New User
Default LS rods in sohc, need some help
i need to know what exactally needs done to put the LS rods into a SOHC d16a6 motor
i know the wrist pin need to be modified or something, can anyone give me more info on doing this?
Old Dec 6, 2002 | 12:12 AM
kinesistech's Avatar
Default Re: LS rods in sohc, need some help (91_EF_Civic)
The wrist pins are different size. You need a bushing that fits the ls rod and the sohc wrist pin. I believe that need to be shaved so the rod fits he piston.
Old Dec 6, 2002 | 12:18 AM
Timmayeg's Avatar
New User
Default Re: LS rods in sohc, need some help (kinesistech)
thanks
anyone else?
any ideas of who can do this for me, and about how much it costs
Old Dec 6, 2002 | 04:08 AM
CRXGSR's Avatar
See if this helps.
https://honda-tech.com/zerothread?id=267641&page=1
Old Dec 6, 2002 | 02:29 PM
Timmayeg's Avatar
New User
Default Re: LS rods in sohc, need some help (GTI 1.8t)
thanks
Old Dec 6, 2002 | 03:12 PM
earl's Avatar
It almost seems like it would be close to the same $ to buy a set of Eagle Rods as to do the machine work?
Old Dec 6, 2002 | 11:48 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: LS rods in sohc, need some help (earl)
earl, you are correct.
You can get the bushings from Crower, like $12 each, then figure another $150-200 to shave, resize, and shot peen the rods.
Old Dec 7, 2002 | 12:00 AM
Timmayeg's Avatar
New User
Default Re: LS rods in sohc, need some help (Mista Bone)
so like 250$$ thats not bad, arent new rods way over 300?
Old Dec 7, 2002 | 05:03 AM
No-Gi's Avatar
Can you even use stock pistons with eagle rods?
Old Dec 7, 2002 | 05:15 AM
337 GTI 1.8t's Avatar
Default Re: LS rods in sohc, need some help (B16aEK)
Eagles can not be used with stock pistons; They are not for press fit applications. They are for free floating applications with circlip-type fastened wristpins.
[Modified by GTI 1.8t, 2:17 PM 12/7/2002]
Old Dec 7, 2002 | 07:01 AM
earl's Avatar
That's what I always thought. I'm glad you verified that. Don't forget the cost of replacing the stock bolts with ARP's (goes along with the resizing).
To anyone considering this, go with the Eagles. No hassles and a much stronger rod than the LS.
Old Dec 7, 2002 | 10:14 AM
Mista Bone's Avatar
D Tranny Guru
Eagle makes "bushed" rods to use stock pistons, you have to ask for them. Most places don't stock them anyways.
Old Dec 9, 2002 | 08:27 AM
Bushed rods can not be used in press fit applications like stock honda...the bushing will rotate in its bore. The bushing is used in those rods as exactly that- a bushing for the wrist pins to rotate within, stock honda pistons are not compatible with free floating wrist pins setups; DO you mean that eagle offers bushed rods for free-floating applications and non bushed for press-fit, such as honda stock pistons?
[Modified by GTI 1.8t, 5:28 PM 12/9/2002]
Old Dec 10, 2002 | 03:58 AM
Mista Bone's Avatar
D Tranny Guru
you know what I meant.
Sorry for the confusion.
benawhati
Oct 13, 2007 08:20 PM
Mr. Self Destruct
Oct 13, 2005 09:32 AM
vtec_yosh
16
Jun 25, 2004 10:59 PM
