question about PS hoses on f22 to jdm swap.
Will the f22 power steering lines clear the head on the JDM h22 engine? It seems like you could skip having to refill and bleed the system by removing the Vehicle speed sensor (ala' the Helms) and not disconnecting the f22 lines from the pump when removing the old engine. I suppse if the f22 hose wont clear the head, then its necessary to use the h22 hose, which will require a re-bleed. Only reason I ask is 'cause Honda PS fluid aint exactly cheap. . .
I really can't remember bleeding my Ps during the swap, but that wasn't my dept. All I can tell you is that I used the PS pump from the h22 and just connected the f22 one to the h22. They should be identiacal (I think?) Hope this helps, and kepp researching b 4 the swap, it'll pay off big time!
