Anyone know Si-R's?
Old Dec 5, 2002 | 07:42 PM
Phoenix1's Avatar
Default Anyone know Si-R's?
ok here's the deal: i have the opportunity to aquire a full Sir fron suspension, including the subframs, control arms, brakes, the works. my question is: is the suspesion geometry different from a USDM EF? Obviously, I'm gonna have to use my rear subframe, but will the control arms, spindles, and upper arms fit my chassis and will the radius rods work with the us front subframe? I'm wondering if the rear subframe has the lower control arm mounting points different from my subframe. thanx for your help...
Old Dec 5, 2002 | 07:57 PM
91vtecripper's Avatar
Default Re: Anyone know Si-R's? (Group7hondawerx)
When I swapped sir suspension to my hatch I had a real bad toe in problem. I had to cut the end links off little bit at the end of the steering arms. I didnt put the subframe on cause I think they are diffrent But I just used spindles And upper arms and everything fit ok.
Tim_EG
Apr 23, 2013 07:17 PM
aquito
Oct 22, 2010 11:29 AM
Dave_Dc2
May 13, 2008 03:56 PM
1xfastxhatch
Suspension & Brakes
Dec 19, 2007 07:48 AM
LoooseGSR
Mar 5, 2004 10:54 AM
