having trouble shifting..help
Old Dec 5, 2002 | 05:30 PM
SpeedMonkeyRacing's Avatar
Default having trouble shifting..help
after i did my b16 swap w/ adjustable shift linkage, i noticed that my shifting is much longer and after driving for a while (when it gets hot), i have hard time shifting. I have to jam into the gear. does anybody have the problem? and how can i solve this problem?
Jeff-
Old Dec 5, 2002 | 05:32 PM
714phil's Avatar
Default Re: having trouble shifting..help (Corporal-Jeff)
have you checked your fluid level?.. if thats not it.. try adjusting the linkage. gl
Old Dec 5, 2002 | 05:34 PM
Default Re: having trouble shifting..help (STD ONEpointSIX)
i've gone thru. a tranny already. this is a new one and it still does the same thing. Some told me if you have shitty short shifter, you will have hard time shifting. you guys think i should invest on a new short shifter?
Jeff-
Old Dec 5, 2002 | 05:36 PM
714phil's Avatar
try putting a stock shifter in. Short shifters are junk IMO
Old Dec 5, 2002 | 05:37 PM
i forgot where mine go. i have a stock GSR one. i'ma try that baby on and see
Jeff-
Old Dec 5, 2002 | 05:42 PM
bryant's Avatar
I agree. Put stock on or maybe even try a differnet linkage
Old Dec 14, 2002 | 12:17 AM
Default Re: having trouble shifting..help (CR-X)
alright. i change dthe shifter that came w/ the hcp adjustable linkagke. however, it still shifts hard as hell when the engine is hot. could this be caused by clutch? or linkage?
Jeff-
Old Dec 14, 2002 | 02:55 AM
keithv's Avatar
make sure your clutch cable is adjusted properly.
Old Dec 14, 2002 | 09:32 AM
deepnite's Avatar
Default Re: having trouble shifting..help (breaka_1_9)
recheck ur tranny fluid..thats call d balky shifting ..when ur fluid become s to slippery for the syncros to mesh
Old Dec 14, 2002 | 09:43 AM
Default Re: having trouble shifting..help (deepnite)
what's the mean? replace the tranny fluid?
Jeff-
twentyhurtz
Jun 19, 2009 03:53 PM
hbyrd8701
Jun 2, 2009 07:38 PM
ProjectDarkBlack
Jan 20, 2005 10:11 AM
DI9ITAL
Feb 8, 2003 09:09 PM
