If use a VTEC water pump and OIL pump
Old Dec 5, 2002 | 04:31 PM
teg92's Avatar
Default If use a VTEC water pump and OIL pump
on a B20 with a ported P75 (LS) head, can I use a nonvtec timing belt or do I need a vtec timing belt?
Old Dec 5, 2002 | 04:50 PM
Kataku2K3's Avatar
Default Re: If use a VTEC water pump and OIL pump (teg92)
Well if you have a VTEC water pump then you will have to run the VTEC t-belt... That's just how that works.. The oil pump doesn't matter... Just the water pump... VTEC water pump = VTEC t-belt.... non VTEC water pump = non VTEC t-belt... Latez
Old Dec 5, 2002 | 04:56 PM
teg92's Avatar
Default Re: If use a VTEC water pump and OIL pump (JDMspecEG6)
Thank you. I was thinking that perhaps the difference between the belts was the actual length maybe cause the VTEC head sat higher on the block than non-vtecs.
Old Dec 5, 2002 | 05:14 PM
tinkerbell's Avatar
the VTEC pump has a bigger pinion gear, ie 22 teeth over 19 teeth...
dunno if the cams are higher or not...
why do you want to use a VTEC water pump?
t..
Old Dec 5, 2002 | 05:19 PM
teg92's Avatar
Default Re: If use a VTEC water pump and OIL pump (tinkerbell)
t..
It is my understanding that the VTEC water pumps flow more than nonVTEC water pumps. Thats why I want to run a VTEC water pump!
Old Dec 5, 2002 | 05:36 PM
JeremyL's Avatar
why would a water pump affect the timing belt?
Old Dec 5, 2002 | 05:48 PM
Kataku2K3's Avatar
Default Re: If use a VTEC water pump and OIL pump (JeremyL)
different number of teeth just as tinkerbell said... non VTEC = 19 VTEC = 22... Therefore they use a different belt... There has been a lot of long discussions about this so i'm not goin to go into it... Latez
Old Dec 5, 2002 | 08:09 PM
tinkerbell's Avatar
what engine for?
why is a higher flowing water pump better?
bigger is not better.
maybe you could fit a 3.5in exhaust? it would flow better?!?!?
t..
Old Dec 6, 2002 | 07:02 AM
teg92's Avatar
what engine for?
t..
Engine? A B20B making power till 9000rpm. And in the case of coolant, I believe that more circulation will yield better cooling.
Old Dec 6, 2002 | 02:24 PM
tinkerbell's Avatar
making power to 9000rpm.
that is fine, you need the VTEC pump it is designed to reduce the coolant flow at higer RPM.
the B20 pump has a higher flow rate anyways, for high RPM cooling, you need a lower flow rate pump
t..
PS in the case off cooling, a faster flow rate will circulate the coolant too quickly for it to actually absorb the heat effiecntly!!
which will lead to overheating...
Old Dec 6, 2002 | 06:20 PM
non-VTEC's Avatar
with a non-VTEC head use: non-VTEC water pump and non-VTEC timing belt
with VTEC head use: VTEC water pump and VTEC timing belt
with both setups you should use a VTEC oil pump assembly........i belive the belt tensioners are the same for VTEC and non........
julianbc2
Apr 4, 2010 11:59 AM
MiKeAhOwSkI
Dec 30, 2004 04:02 AM
bens_redeg
Jul 10, 2004 07:11 AM
Tinker219
May 5, 2003 08:22 AM
ILOVEGIRLS
Sep 30, 2002 11:07 PM
