b16 and LS crank pully the same?
Old Dec 5, 2002 | 03:48 PM
EFing8's Avatar
Default b16 and LS crank pully the same?
As topic states, are these pullies the the same? I have an LS one kicking around and want to take it to the machine shop and have the 2 extra slots taken off.
Old Dec 5, 2002 | 03:50 PM
Kataku2K3's Avatar
Default Re: b16 and LS crank pully the same? (CND_CRX)
Yup, should work fine.... So you have the PS and A/C pulleys ground off??
Old Dec 5, 2002 | 04:13 PM
EFing8's Avatar
Default Re: b16 and LS crank pully the same? (JDMspecEG6)
yes i want the PS and A/C ground off. Less rotating mass and more room for the swap, that crank pull can sometime be a pain while trying to fit b-series into EF chassis. I have done enough to do it fast, but I would still like to have those ground off.
Old Dec 5, 2002 | 04:30 PM
Kataku2K3's Avatar
It's not that bad... I put a B18C into my friend's 88 CRX... It clears, but a single underdrive pulley would probably look cleaner... I hate A/C and PS anyways they just make the motor look too cluttered... So does ABS and cruise... I would just get an Unorthodox one.. They look way clean... Latez
Old Dec 5, 2002 | 05:34 PM
EFing8's Avatar
This has been discussed to death, I want to keep the harmonic balancer in the stock pulley. Unorthadox does not offer this. Plus I bet that this is a cheaper way to do it.
Old Dec 6, 2002 | 09:57 AM
iwhichisme's Avatar
they arent the same size, the b16 crank is slightly smaller than the ls. But the ls and the gsr are the same size. I think it goes by displacement, quote me if im wrong though
Old Dec 6, 2002 | 12:29 PM
Jesse H's Avatar
Default Re: b16 and LS crank pully the same? (iwhichisme)
why would we quote you if you were wrong?
Old Dec 6, 2002 | 01:36 PM
Brad's Avatar
In a related question, could I bolt up a b16a crank pulley and alternator to a b20 and use the same b16 belts? And will this not overdrive the accesories like I heard the b20 crank pulley does? thanks.
Old Dec 7, 2002 | 02:15 PM
LOtownNateB's Avatar
Default Re: b16 and LS crank pully the same? (Brad)
Payn Technologies sells lightened stock crank pulleys ... i believe they are rebalanced too. www.payntechnologies.com
Fezzie
Aug 27, 2006 07:19 AM
Fezzie
Aug 25, 2006 12:00 PM
MenaceL.A.671
Jun 29, 2004 05:50 PM
JMinSi2000
Jul 16, 2003 06:45 PM
