code from ecm,map sensor,vss,fuel supply
1994 honda prelude with promax turbo, check code's from ecm
#1 map sensor
#2 vss vehicle speed sensor (where is at on tran's)
#3 fuel supply
any info would be great
#1 map sensor
#3 fuel supply
i think you are getting a map code because of the turbo, do u have ne check valves going to the map sensor? the vss is located on the tranny, the sensor might just be loose or unplugged. fuel supply???
Yes I have a qty of 4 check valve's before map sensor
do you know if the vvs is one off for the prelude our is something i can pick off other honda?
TEAM SL
21
Aug 23, 2004 04:04 AM
