I need resident *expert* help: B-series tranny
I have a b16 LSD tranny on a GS-R, the gears are awesome...that is when I can get into gear
Here's the scenerio:
I have a relatively new master, new slave, and good clutch.
So I'm rollin around in any gear and I go to shift into 3rd or 4th and it wont let me in w/o full grindage...almost like I dry-shifted really bad. I am aware that the 3rd synchro is probably gone, but not all the time do I experience this issue nor does that account for 4th gear grindage, does it?
Now I've bled and re-bled the system, so I'm relatively confident theres no air in the system, I don't see any leaks in any of the lines
The other thing is that sometimes it feels like when I go to depress the clutch (after being run for a while) it feels like it's already engaged, and it jumps into gear, or it becomes difficult to get out of gear...like the clutch isn't fully engaged.
If I think of any other info I'll be sure to post it up...What do you guys think? thanks in advance for your help.
Mike
Mike
heres what i would check
1) pedal, readjust your pedal to make sure the slave cylinder is pushing the releast fork all the way, it could not be moving it enough
2)tranny fluid, when was the last time it was changed? 2 quarts of honda MTF never hurt anyone.
does this happen in all the gears? or just a couple?
Symptoms sound like a broken clutch disc spring. You sure the clutch is good? Also make sure that whoever changed your tranny fluid last did not use gear oil (90 wt.)
Trans fluid: 10/30( i think, whatever was recomended by the local shops), last filled/changed ~5k ago.
It seems only to happen in 3rd and occasionally in 4th. I notice the trans not wanting to let other gears release also, like 1st into 2nd, However this is also occasional. I experience the bulk of the problem in third only with the occasional exception of 4th.
clutch spring is something I had'nt considered, can you describe some other sytmptoms/what to look for(w/o opening everything up)?
If this sounds hopeless, forgive me...I have had this problem for a while and I cannot figure it out...
you really think the viscosity of the oil will affect *specific* gears?
first things i'd check:
1.make sure clutch is disengaging. check the throw of the slave cylnder.
2.change your tranny fluid and put in honda mtf. overfill it a little, since slightly low fluid can do weird things to a honda tranny. check the old oil for any metallic flakes.
Ok, I'll do all of the above options and post the results accordingly...
I do thank all of you for your exra insite on this most frustrating issue
Ok, I am now officially an advocate for honda fluids. I replaced the old stuff w/ the recommended oil and experienced a considerable difference in shift quality
It did'nt really affect 3rd, but I assume that's a synchro, however it made things a lil better all around
Thanks guys
Thanks guys
