what parts should i buy?
Old Dec 5, 2002 | 10:16 AM
professorman's Avatar
Default what parts should i buy?
My head gasket was blow the other day, and so now i am replaicing it. what other gaskets should be replaced while i am at it? my mechanic says that intake gasket and the valave cover gasket should be replaced. is it necessary to replace the exhaust gasket as well?
i am also conidering to change the timing belt as well, but i found out that the accord has two, which are $40 each at the dealer, but the auto parts store are selling them for $23 each. I am on a tight budget, so i was wondering what is your opinions on changing this? should i just wait and get the honda or can i get the one at the auto parts store?
Old Dec 5, 2002 | 10:08 PM
Accord94DX's Avatar
Default Re: what parts should i buy? (profroopchan)
Replace both those gaskets and use only honda parts. Your mechanic isn't bullshitting you on this one.
[Modified by Accord94DX, 11:09 PM 12/5/2002]
Old Dec 6, 2002 | 01:33 AM
WhoNeedsVtec's Avatar
Default Re: what parts should i buy? (Accord94DX)
how many miles on your accord? timing belt/water pump should be replaced at 90K so if you replacing the timing belt mine as well replace the water pump same some money and time in the long run
Old Dec 6, 2002 | 06:00 AM
Stew Pidasso's Avatar
Default Re: what parts should i buy? (WhoNeedsVtec)
Also the timing belt I got at the local parts store was made by Goodyear. I would surely hope that that is a name you can trust...
Old Dec 6, 2002 | 06:47 AM
Desslok's Avatar
Default Re: what parts should i buy? (Stew Pidasso)
http://www.hondaaccordindia.com/see/...imingbelts.asp
wittynamessuck
Honda Civic (2001 - 2005)
14
Oct 27, 2011 07:28 AM
erikwithak
Jul 17, 2009 01:15 PM
LstCivic
Feb 16, 2008 10:19 PM
el3vate
Aug 21, 2005 07:30 AM
PINKMONST3R
Jun 15, 2004 11:45 AM
