CRV camber kits? Are there any!!
Which camber kit can I use for my 98 CRV? I'm wondering if the accord camber kit would work?I have a really bad camber problem in the rear or my car. Must be from the weight of the system cause even when I adjust the coilovers on my crv it does nothing for the camber.
yeah, you go to HD and get some longer bolts, can't remember what diam. and length. Then you pick up some washers usually 4 or 6 per side. You take the bolts out of the upper rear arm that go into the body, install the washers, throw the bolts in with a little thread lock. Presto! instant alignment for 6$
