Axle help
Old Dec 4, 2002 | 09:58 PM
kshymkiw's Avatar
Default Axle help
Does anyone know a good way to pop the axles out, without dissasembeling the enter hub and damper fork and everything.
Old Dec 4, 2002 | 11:32 PM
Urban Business
Guest
Posts: n/a
Default Re: Axle help (kshymkiw)
easiest: pull wheel. hit axle nut w/ an impact gun 650lbsof trq prolly required. other wise hit em w/a breaker bar and a big *** extention with the car on the ground. unbolt castle nut on lower ball joint. split ball jount w/ a ball joint splitter ($8 parts store, looks like a big fork) hit that bitch w/ a sledge hammer untill the joint splits. fromthere you canpull the hub off the axle and pull the axle of the diff.
or
if your swaping a trans or clutch or something. pull off wheel. seperate ball joint (lower) pull hub w/ axle out of diff. works if you cant get your axle nuts off.
Old Dec 5, 2002 | 04:01 AM
EP3_05's Avatar
Default Re: Axle help (TorteX)
or
He is right Works like a charm everytime
Old Dec 5, 2002 | 04:26 AM
keithv's Avatar
Default Re: Axle help (91civic)
if you use a ball joint splitter, grease the fork end up so you don't rip the ball joint boot.
also, you can just remove the lower control arm to remove the axles. you might have to pull the lower shock mount bolt as well though. whenever i have pulled the axle with just removing the control arm, the shocks were all ready removed.
just my $0.02.
Old Dec 5, 2002 | 06:12 AM
Rob!'s Avatar
Default Re: Axle help (breaka_1_9)
just my $0.02.
well said...have fun
Old Dec 5, 2002 | 06:18 AM
forever slow EG6's Avatar
Default Re: Axle help (RaceFacer)
ok dont mess with the ball joints alot of times they wont even split. just undo the lower control arm and it all swings to the side. there might be one other thing the unbolt but i cant remember.
Old Dec 5, 2002 | 06:20 AM
JoshDM's Avatar
Default Re: Axle help (forever slow EG6)
i unbolt the upper control, pull down hub assy. and slide to the side axle comes right out. i've swapped both axles in 20 minutes
Old Dec 5, 2002 | 06:56 AM
keithv's Avatar
i just remembered myself (since i did this last night)... if you have an si, you have to remove the front sway bar.
keithv's Avatar
Default Re: Axle help (JoshDM)
very good idea. i'll have to try this sometime.
thw_goalie
Aug 12, 2012 10:39 AM
boarding2008
Jul 29, 2010 05:56 PM
Mr. Giggles
Jan 23, 2007 06:15 PM
teamvirus
Dec 17, 2005 02:56 PM
RicedREX
Feb 26, 2004 05:33 PM
