Where could i tap the ITP sensor?? *pic*
as you may know I'm doing the Y8 intake mani swap, and on my a6 mani it got the ITP sensor. On the Y8 on the other hand, it doesn't have one correct me if i'm wrong pees.. Now my question is where is the best place i could tap this baby? Here is the pic what I'm talking about.. Your input will be greatly apprecaited..
[Modified by 4thGSi, 8:46 PM 12/4/2002]
just hook it to a vaccum line... tee it off soem thing.. you take out the whole senso then it should read vaccum under pressure... thats how we did it on a 93 si hatch with a 00 b16 and 98 type r engine harness
I tapped mine in the center of core plug. Also drilled two small holes, tapped and reused the originaL screws. Almost looks factory and if you happend to screw up I would bet you could pick up another core plug from a machine shop.
Don't tap it into the manifold, just drill a hold in your intake, stock tubing, whatever it is. Don't screw up a perfectly good Y8 manifold.
Yeah, i'm staying away of doing that route.. That's why i need your opinions guys.. So i can drill a hole in my AEM intake tube is that what you trying to say?
[Modified by d357r0y, 1:27 PM 12/5/2002]
[Modified by d357r0y, 1:42 PM 12/5/2002]
yes, i have my stock air junks on.. i tapped into the bottom side of mine.. it looks stock still
if you want a picture of it, let me know and ill send you one. bling bling..
yo cuz you can put it in ur aem tube remember the tube that we close when we put the breather you can put it there.....christmas is past approaching
bump
no. no codes at all.. works fine. im sure the temp of the air is a little cooler there than the intake manifold too.. so it could possibly mean a slight power gain.
just make sure you dont make the hole too big for the sensor. i made mine a tight fit and then pushed it in and used 2 little bolts/nuts to secure it.
[Modified by 4thGSi, 11:57 AM 12/5/2002]
.Cool! What kind of tb did you used on your y8? I got a teg 91 ls tb and I noticed that the choker or floater that adjust the rpm when it's warm it has different hole on the bolt hole for the teg tb.. I might just drill another hole so i can use my a6 choker whatever you call that thing..
LilCivic04
Jul 23, 2006 10:47 PM
wwwaskouniversitynet
May 31, 2005 03:52 PM
MrTodd
Aug 1, 2002 10:07 PM
