D15B1 restrictor plate
Old Dec 4, 2002 | 06:47 PM
91 civic's Avatar
Default D15B1 restrictor plate
will removing the restricor plate cause any problems? Will I have to get a pm5 ecu instead of using my pm9? Is the exhaust manifold on the 91 std the same as the si?
Old Dec 4, 2002 | 06:49 PM
FourthGenHatch's Avatar
Default Re: D15B1 restrictor plate (91 civic)
If the restrictor plate is that stupid brass colored piece of metal in the air chamber removing it does nearly nothing, my car seemed exactly the same before and after.
Old Dec 4, 2002 | 06:52 PM
91 civic's Avatar
Default Re: D15B1 restrictor plate (FourthGenHatch)
Well then would changing the throttle body increase air flow if removing the restrictor plate does nothing?
Old Dec 4, 2002 | 07:01 PM
Well changing the throttle body would basically mean doing a MPFI swap.
tarpus91
Engine Management and Tuning
Apr 15, 2017 04:19 PM
xparalandrax
50
Oct 17, 2013 01:40 PM
BigBlock22
Jun 4, 2010 03:56 PM
cstem
Nov 30, 2003 04:03 PM
civicracer1993
Aug 15, 2002 07:16 PM
