What Racing Seats should I get?
Old Dec 4, 2002 | 05:35 PM
FourthGenHatch's Avatar
Default What Racing Seats should I get?
I think I'm finally going to break down and get nice seats. I think I will go with the non reclineable since they are cheaper. What brands make a good one for cheap. I see Momo, Sparco, and what others. And what sites can I buy them from?
[Modified by FourthGenHatch, 3:05 AM 12/5/2002]
Old Dec 4, 2002 | 05:38 PM
Rob Dizzle's Avatar
Default Re: What Racing Seats should I get? (FourthGenHatch)
how big/tall are you?
you using this for street?
if you are going 1 piece racing shell seats, you will need a roll bar or roll cage to protect you in a roll-over
the jdm itr recaro seats are a comfy seat, great quality, and very supportive
if i had the money i would get those
Old Dec 4, 2002 | 05:44 PM
Default Re: What Racing Seats should I get? (Bob-DC2)
6'2'' 125lbs. I don't race. And I don't want to spend more than $600 really, give or take a hundred.
Old Dec 4, 2002 | 05:57 PM
Optiks.'s Avatar
why a roll cage if its a racing seat?
Old Dec 4, 2002 | 06:08 PM
Default Re: What Racing Seats should I get? (Optiks)
Yeah why would I need a rollcage with any seat I got, how are they more unsafe than a stock seat?
I'm not talking some kind of crude metal seat, I mean a fully unholstered seat, but not reclineable, and with holes for my harnesses.
Old Dec 4, 2002 | 06:17 PM
dmotoguy's Avatar
I'm not talking some kind of crude metal seat, I mean a fully unholstered seat, but not reclineable, and with holes for my harnesses .
thats why you need a rollcage
Old Dec 4, 2002 | 06:19 PM
CHRIS 1.8's Avatar
Rollcage for life.
Old Dec 4, 2002 | 06:22 PM
MOCrxHf's Avatar
Default Re: What Racing Seats should I get? (B16A1-EF8)
I'm getting a four point rollbar Monday. I'd get Corbeau Forza's. I know of a place you can get 2 seats and 2 rails shipped for 620.
Old Dec 4, 2002 | 06:23 PM
Default Re: What Racing Seats should I get? (MOCrxHf)
"I know of a place you can get 2 seats and 2 rails shipped for 620."
Pass it along.
Old Dec 4, 2002 | 06:33 PM
MOCrxHf's Avatar
http://www.importdirectusa.com 1-877-988-9284, that is what they quoted me when I called there a month or so ago.
Old Dec 4, 2002 | 06:41 PM
keithv's Avatar
most racing seats don't allow the use of the stock seat belts. therefore you need some kind of way to strap yourself in and a harness should be mounted to a roll cage to give you the most protection.
Old Dec 4, 2002 | 07:20 PM
EFing8's Avatar
Corbeau Forza all the way, and if you are a larger (fatter) guy, get the Forza 2, for your plump racer.
Old Dec 4, 2002 | 07:34 PM
skud_dusty's Avatar
Default Re: What Racing Seats should I get? (CND_CRX)
plump racer
lol thats great
Old Dec 4, 2002 | 07:47 PM
drunk's Avatar
Default Re: What Racing Seats should I get? (skud_dusty)
620!!!! that is expensive as ******* hell......i can get two corbeau forza's shipped to my door for 550....reaction motorsport in fl.....
Old Dec 4, 2002 | 07:49 PM
Default Re: What Racing Seats should I get? (drunk)
Yes the cheaper I can get these seats the better. Let me know of all these sites.
Old Dec 4, 2002 | 08:05 PM
Urban Business
Guest
Posts: n/a
Nex. 398 shipped for a pair w/ brackets 100% fiberglass. 5pt harness aceptable (5th point in inbetween bottom cushin). 11lbs w/o bracket 14lbswith. varouse colors http://www.dragonintakes.com
i use them w/ my factory seat belts and havent moved a smidge. but see how my **** is routed. left side it thru, right side i go over to the buckle. can fit the strap thru the buckle but its un comfortable. snug as a bug doing it the way i have it set up. im small too
allof the fabric velcros off so you can wash it. head rest padding is removeable so you can fit a helmet in there. leave the pad on if your not wearing a helmet. hitting fiberglass doesnt feel good w/o a pad
[Modified by TorteX, 11:07 PM 12/4/2002]
Old Dec 4, 2002 | 08:18 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: What Racing Seats should I get? (TorteX)
How comfortable are those seats? It seems like they would be sorta uncomfortable? Im starting to loko for new seats...i drive my car ALOT every day so i need something comfortable. How hard were they to install...what type of brackets did you get? Thanks alot man.
Sean
Old Dec 4, 2002 | 08:25 PM
Urban Business
Guest
Posts: n/a
Default Re: What Racing Seats should I get? (sCeRaXn)
i have mine at a 90* angle. if your not used to it its weird. however they're some of the most comfortable seats ive ever sat in.
comfort for me = sence of security ie not sliding around, great shoulder suport and hip suport
there is a foam pad in the lumbar area to suport your back
its a 2 piece bracket. they're L shaped. requires drilling into floor and mounting w/ non suplied bolts. bolts that mount brackets to seat are suplied. theres brackets do not allow you to slide. id imagine you could transfer a normal seat bracket and bolt it to the bottom of the supplied bracket then bolt back into stock location to slide around. ive drilled so many holes to mount a variety of seats so it wasnt a big deal to me.
i'll post pics of how i did it tomorrow. cam is out of bateries and my pc cable is at work.
[Modified by TorteX, 11:26 PM 12/4/2002]
Old Dec 4, 2002 | 08:32 PM
Lamchop0000's Avatar
my friend has a pair of those NEX's in his crx. MY thoughts about them are that there are perfect angle and comfy. the only part i realy dont like about them are that the shoulder parts are wobbly. but ill get them because its cheap
[Modified by lamchop0000, 9:47 PM 12/4/2002]
Old Dec 4, 2002 | 09:08 PM
EG8R's Avatar
Default Re: What Racing Seats should I get? (lamchop0000)
6'2" and 125lbs??? You serious??
batman_22's Avatar
hey here are some seats they are exactly like sparco only they are DAD racing seats they are pretty cheap only like 400 bucks for BOTH!! and they recline look into them i would if i wouldnt of got integra seats, but i'll send you these web sites right here. or go on ebay and type in racing seats.
http://search.ebay.com/search/search...ry=d+a+d+seats
http://search.ebay.com/search/search...y=Racing+seats
i would look at these i dont just trying to help you know so you dont pay that much well enjoy
Old Dec 4, 2002 | 09:20 PM
shorti's Avatar
Default Re: What Racing Seats should I get? (mr. skelly)
that's what i was thinking. gezus man are you only made of bone?
Old Dec 4, 2002 | 09:23 PM
travis's Avatar
This...
What Racing Seats should i get?
and
I don't race
...don't all lead to the same answer and don't fit well together. A one-piece race bucket is designed for track use and is a huge compromise when used on the street (in terms of comfort, convenience, and safety).
What you should look for is a two-piece reclinable non-race seat with good lateral support. Also, if you care about safety and comfort, things like "the cheaper the better" shouldn't be in your vocabulary. You don't have to spend $1,500 on a pair of JDM Recaros to get quality seats, but you also shouldn't spend $300 for a pair of seats. Those are made to look good, but nobody in their right mind (or nobody who's sat in a quality seat) would want to sit in them for very long.
[Modified by travis, 3:54 PM 12/5/2002]
G2turbo_terror's Avatar
Default Re: What Racing Seats should I get? (batman_22)
If I had the money I'd get those in a second. Untill then I'm gonna get some nicer OEM ones, can't have vinal when summer comes around.
Old Dec 4, 2002 | 09:34 PM
zRd#1's Avatar
Default Re: What Racing Seats should I get? (G2turbo_terror)
Sparco revs. i just got em!
