my flywheel wont come off!?
Old Dec 4, 2002 | 04:43 PM
fastludeh22's Avatar
Default my flywheel wont come off!?
i took all the bolts out so i can swap it from my old engine to my new one, and it wont budge...i thought it was supposed to come right off, i dont want to bend it from pring, its an alum. one
Old Dec 4, 2002 | 06:36 PM
kotetu's Avatar
Default Re: my flywheel wont come off!? (fastludeh22)
I haven't taken out a flywheel, but if you must use some kind of force on it, use a rubber malet, that shouldn't damage anything.
Old Dec 4, 2002 | 08:06 PM
Default Re: my flywheel wont come off!? (kotetu)
tried, i even tried slightly prying no luck, i was told it should come right off
Old Dec 4, 2002 | 08:40 PM
Quiklude's Avatar
damn, what kind of flywheel, that sucks stock ones come off like nothing, rubber mallet is your best idea, possibly pry from 2 diff sides at once (not really a great idea tho).
Old Dec 4, 2002 | 09:13 PM
prelude1897's Avatar
2 words.... Air Tools An air gun would take it right off
Old Dec 4, 2002 | 09:14 PM
Quiklude's Avatar
Default Re: my flywheel wont come off!? (prelude1897)
how would an airgun take it off, he already has the bolts off,
Old Dec 4, 2002 | 09:40 PM
Default Re: my flywheel wont come off!? (Quiklude)
its a cm 10 lb, ill try again in the morning...ot, but does anyone have a link or something to help me install h23 tenisor on the h22 from scratch, there is nothing on there now
Old Dec 4, 2002 | 10:12 PM
EH2DX's Avatar
hm... mine came right off after i got the bolts off... try turning the motor a little from the crank, see what happens.
Old Dec 4, 2002 | 10:17 PM
SuperSH's Avatar
Default Re: my flywheel wont come off!? (BB1)
Try this.. Heat. in the form of a blow torch and not a lighter. Heat the entire flywheel slowly. The heat will expand the flywheel enough to get it off the crank but be sure to use thick gloves. Be carefulbecause the fly might just decide to fall off.
Old Dec 5, 2002 | 06:06 AM
Default Re: my flywheel wont come off!? (SuperSH)
the engine is in my house so i am not worried about it falling. it wont do any damage it by heating it?
Old Dec 5, 2002 | 07:56 AM
My bad, I just misread that he had the bolts off.....Nevermind about my last post
Old Dec 5, 2002 | 11:57 AM
BoostedH23a1's Avatar
well if u heat it dont fry the crank seal.
Old Dec 5, 2002 | 12:00 PM
Boostless97Lude
Guest
Posts: n/a
actually, since it is aluminum, excessive haet, can and will warp it, do not use heat, i suggest you use a rubber mallet and hit it, kinda hard, in a criss-cross motion on the flywheel, similar in patter to tightening lugnuts
Old Dec 5, 2002 | 12:49 PM
Default Re: my flywheel wont come off!? (Boosted97Lude)
well i tried BEATING it w/a rubber mallet...nothing so i just went ahead and heated it like i have done to crank pullys, not too much but enough. it took a good bit of heat AND hitting it w/the mallet...but its off and it doesn't look warped, but i will have it checked when it is resurfaced
Old Dec 5, 2002 | 12:57 PM
bgod's Avatar
cm flywheels use replaceable plates. you don't resurface them.
doubt you warped the flywheel.
Old Dec 5, 2002 | 01:11 PM
Default Re: my flywheel wont come off!? (bgod)
well how much does a new plate cost? i cant even resurface a real tiny layer, there is hardly any where, i can barly feel a little wear on it. i only put 10k at the most on it
Old Dec 5, 2002 | 09:51 PM
SuperSH's Avatar
Heat, not only good in bed.
Nathan007
Jun 17, 2009 08:56 PM
tmrtwo
Jan 6, 2007 02:34 PM
f150harleytruck7
Feb 7, 2006 09:55 AM
nevin
Nov 26, 2003 09:06 PM
daniel89civ
Sep 5, 2002 06:59 PM
