New Brake rotors
Old Dec 4, 2002 | 09:33 AM
-=DFOX=-'s Avatar
Default New Brake rotors
I need some new rotors and want to put them on myself, do brand new ones need to be turned? like trued or anything? where is a good place to find something a little better than OEM, maybe something drilled. thanks guys.
Old Dec 4, 2002 | 09:41 AM
Accord94DX's Avatar
Default Re: New Brake rotors (-=DFOX=-)
some cheap *** rotors need to be turned prior to initial install, most high quality ones don't.
I suggust doing the following:
https://honda-tech.com/zerothread?id=223096
Old Dec 4, 2002 | 09:42 AM
urbanlegend21's Avatar
New User
no drilled, no slotted, Brembo blanks
http://www.collettimotorsports.com
Old Dec 4, 2002 | 10:30 AM
-=DFOX=-'s Avatar
Default Re: New Brake rotors (urbanlegend21)
I found some Brembo's on ebay, new in the box for 65.00 a pair shipped, sound decent? so i shouldnt have to do anything but bolt them on with some new pads and go right?
Thanks for the help.
Old Dec 4, 2002 | 10:42 AM
New User
correct
Old Dec 6, 2002 | 03:59 AM
Stew Pidasso's Avatar
HAHA, easier said than done.
Old Dec 6, 2002 | 06:29 AM
-=DFOX=-'s Avatar
Default Re: New Brake rotors (Stew Pidasso)
Well, obviously, it's a little more than that, I just mean, I should be able to put those rotors and new pads and not need to have them turned.
Old Dec 6, 2002 | 09:18 AM
New User
yep, might want to flush your brake fluid too
Old Dec 6, 2002 | 09:23 AM
GZERO's Avatar
you stole my words, hehe, well, try to use a better fluid, maybe DOT4 or 5.1
Old Dec 6, 2002 | 11:53 AM
CardDealer's Avatar
Banned
Default Re: New Brake rotors (GZERO)
Modified by CardDealer at 4:10 PM 11/17/2006
Old Dec 6, 2002 | 11:56 AM
Accord94DX's Avatar
Default Re: New Brake rotors (schlit)
Uh, doesnt he have to remove the hub assembly? meaning he has to do a bit more than just bolt the things on. tell me if i'm wrong.
he does.
Old Dec 6, 2002 | 12:04 PM
YodiBrodi's Avatar
Default Re: New Brake rotors (Accord94DX)
brakes were the biggest pain-in-the-*** repair i've had on my car so far. well that and the 90k tune-up (the crank pulley was a BITCH!)
Old Dec 6, 2002 | 12:42 PM
New User
Default Re: New Brake rotors (YodiBrodi)
I got rotors down to about 25 minutes
Old Dec 6, 2002 | 01:02 PM
-=DFOX=-'s Avatar
Thats what I like to hear, I figure as long as it doe's not require any special tools, should be cool. I was going to use OEM pads, anything better thats cheaper than 50 bucks a set? I dont want them squealing on me either. I used some cheapos from autozone once, noisey buggers, and switched back to OEM, nice and quiet. Thanks for all the help.
Old Dec 6, 2002 | 01:15 PM
ArchAngel Sabastian's Avatar
New User
Old Dec 6, 2002 | 02:54 PM
KTeller8's Avatar
Default Re: New Brake rotors (ArchAngel Sabastian)
ebay isnt bad. if you guys want. i match nopi's online price for the rotors.. so anyone needs them they are bit cheaper
Old Dec 9, 2002 | 06:57 AM
-=DFOX=-'s Avatar
Default Re: New Brake rotors (KTeller8)
Someone in another forum said there are some bearings to press out? yeah? its a 96 accord.
Old Dec 9, 2002 | 08:04 AM
New User
Depends, i pull the whole assembly out, bearing, race, and all.
When I put it back in I never-seize the **** out of the back side of the race so it will never be that tough to get out
if it is first time you will need a good weekend and a whole lot of patience to get it done, then it will be like cake
the only special tools you will need are a ball joint seperator and 36mm socket
Old Dec 9, 2002 | 08:31 AM
Kazmans94cord's Avatar
who wants to take a road trip down here to help me do my swap this weekend? any takers?
free and green too!!!
[Modified by Kazmans94cord, 11:31 AM 12/9/2002]
Old Dec 9, 2002 | 08:32 AM
Accord94DX's Avatar
Default Re: New Brake rotors (Kazmans94cord)
can you pay for gas?
btw, i drive a plane
Old Dec 9, 2002 | 08:34 AM
sure...pshh...money aint a thang
Old Dec 9, 2002 | 10:21 AM
gringo7718's Avatar
that sounds like a good deal assuming all i have to do is order you around while i smoke ya cheeba. hahaha- well if i didn't live in miami i would be there. good luck
bigslimdog
Oct 26, 2005 09:34 AM
pharmaccord
Aug 3, 2004 05:28 PM
travis
14
Jan 12, 2004 02:08 PM
Chris
Jun 20, 2001 10:19 AM
