What Should I Do??????
Old Dec 4, 2002 | 09:24 AM
xSkatePunkx's Avatar
Default What Should I Do??????
I bought a CRX (88 DX) for 1900....everything is perfect in this car except for its missing the rear hatch cover....anyways....I was driving down the freeway at about 80mph, the car shut off my temp gage was well above RED, and it wouldnt start......i took it in for a diagnostic...ive got radiator coolent in my cylinders, now most likely my head has a crack in it right??? or could it just be the gasket? or is it a cracked block? fucked up valves? It could be any of these??? should i rip the head out and look???? IM SO PISSED, help me?
i dont check often email me if you can....EYEHATEMYSQUITOS@HOTMAIL.COM
Old Dec 4, 2002 | 09:35 AM
Hondasaurs's Avatar
Default Re: What Should I Do?????? (xSkatePunkx)
Sounds like you have a bad head. I have an SI head (about 1000 miles on it) and Si intake if your interesed. You would have to do DPFI to MPFI if your interesed in it.
Old Dec 4, 2002 | 09:37 AM
Default Re: What Should I Do?????? (ZC_CRX)
whats mpfi????? Im new with cars.....i have a DX block and i heard that Si heads fit.....would i have to change fuel pressure ???? or what?
Old Dec 4, 2002 | 09:40 AM
forever slow EG6's Avatar
dx is dual point fuel injection. si is multi point fuel injection u have to convert the dx to mpfi for the head to work. be careful doing this is if ur not mechanically inclined my friend did it without knowing what he was doin and screwed up his car for good. now he needs a new engine harness. not cheap!
91CRXsiR
Apr 5, 2004 12:19 PM
civicracer1993
17
Nov 18, 2003 05:20 PM
crx2306
May 21, 2003 08:27 PM
maximedx
Dec 5, 2001 09:07 AM
ODX
13
Nov 5, 2001 02:29 PM
