LS-VTEC fuel pump????
Old Dec 4, 2002 | 09:03 AM
civicdragger818's Avatar
Default LS-VTEC fuel pump????
I have a 88' dx with a 93' b18a in it running a pr4 ecu. This is my second car to have this swap in and I kinda wondered with the first about the fuel pump. Some of my friends said it would be fine to keep the dx fuel pump. When I was driving the other day I just happend to look down at my ecu to notice that it was throwing a code 43. This is a fuel system code. I am fixing to put a pr3 b16a head on my car and was wondering if any of you guys recomend using a different fuel pump from stock or should the stock fuel pump be enough for this setup??????
Old Dec 4, 2002 | 09:25 AM
Spade's Avatar
Default Re: LS-VTEC fuel pump???? (civicdragger818)
I would get a larger fuel pump.
YOu can get a used Turbo Eclipse fuel pump and that will work or just spend the 125 and get a 255 lph in prepairation for a turbo
EJ8CIVIC
Jul 5, 2015 12:07 PM
VspecSiR
May 17, 2004 04:37 AM
85mm LsVTEC
Dec 22, 2003 10:19 AM
civicdragger818
Dec 4, 2002 09:50 AM
