2 Questions: Oil & Brakes
Old Dec 4, 2002 | 06:58 AM
Sand's Avatar
Default 2 Questions: Oil & Brakes
I recently purchased a lady owned '98 prelude that needs just about every maintenence possible. While I save money to trick it out, I just want to make sure I treat it right. My questions are: 1. Is Mobil 1 oil recommended for the 2.2 engine? If so, what weight? Next, when I change the brake pads, since I've never owned a car with rear discs. I need to know. Is there any special procedure for changing them (ex. Does the front or rear need to be done first? Is there anything to avoid doing that will cause major damage?) Any suggestions would be nice.
Old Dec 4, 2002 | 07:02 AM
Desslok's Avatar
Default Re: 2 Questions: Oil & Brakes (Sand)
I use Mobil 1 5.W-30. Front brakes should wear faster than the rear, just check them all.
Old Dec 4, 2002 | 01:26 PM
Perfectionist's Avatar
5W-30 is recommended, but you can use 10W-30 if your temps don't go below 20 degrees F.
Nothing special about replacing pads, except the rear caliper pistons TURN in. The fronts can be pressed back in. BTW, OEM pads work very well and come with the proper grease and shims for original factory performance and quietness.
Also, given it's age and neglect... a full brake system fluid flush would be a good idea.
[Modified by Perfectionist, 10:28 PM 12/4/2002]
Old Dec 4, 2002 | 01:32 PM
The_Oz's Avatar
Ensure first that you are not leaking any oil before purchasing a synthetic brand such as Mobil.
Regards,
Oz
Old Dec 4, 2002 | 01:57 PM
Desslok's Avatar
Default Re: 2 Questions: Oil & Brakes (The_Oz)
Regards,
Oz
Good advice. Also if you change to Sytnthetic, check for leaks afterwards too. Just cause regular oil isn't leaking doesn't mean that the syn won't.
Old Dec 4, 2002 | 03:04 PM
ejprimo's Avatar
Default Re: 2 Questions: Oil & Brakes (sp)
i would use 10w-30 also.
hometheaterman
Dec 3, 2009 05:21 PM
nc-rsx-s
Jun 20, 2005 04:09 PM
GSRnold
Aug 22, 2004 04:29 PM
PearlWhiteAccord
Jul 11, 2002 06:09 PM
Charlie Moua
Feb 25, 2002 06:23 PM
