Question On Engine Swap for 6Th Gen Accord
Hi there, I have a couple of questions about this. I have a 2000 Accord Coupe 4 Banger, 5 spd and I wanted to know what would be the best way to go with a swap. I've heard opinions ranging from an H22A, H22A Type-S, and An H23.(Not sure which of those would fit). I want to eventually super charge it, unless going turbo would be better, I'm not sure. Also, I expected to spend about $3-3,500 on the engine, is this correct and were besides Osaka Motors could I find a good quality engine with some sort of warrenty? If you could share some of your infinite wisdom with me, I would definetly appreciate it, Thanks.
H22A will serve you right..
the swap been covered like 16464 times.
do a search for "h22"
I dont think there's a supercharger for f23a1
or h22...
for that budget
I'll get the swap.
here's some links
https://honda-tech.com/zerothread?id=227593&page=1
https://honda-tech.com/zerothread?id=168378
[Modified by iam7head, 9:47 AM 12/4/2002]
[Modified by iam7head, 9:54 AM 12/4/2002]
or h22...
for that budget
I'll get the swap.
here's some links
I'm like 95% certain Jackson racing does make a SC for the H22 but it won't fit into a swapped 6th gen accord becuase the firewall gets in the way.
just do a turbo if you feel the need for boost. you'll find a lot more info on it since the majority of honda people turbo instead of SC.
$$ gone up like crazy)
