H23 VTEC dyno
Old Dec 3, 2002 | 07:02 PM
satan_srv's Avatar
Default H23 VTEC dyno
For those that wanted to see it here it is:
Now where was 2point6's dyno?
Old Dec 3, 2002 | 07:09 PM
Cottonwoodz's Avatar
Default Re: H23 VTEC dyno (satan_srv)
And again, how long did that motor last??
Old Dec 3, 2002 | 07:10 PM
Honda318dx's Avatar
nnnnnnnn NICE!!! Now, just need a header to get rid of that upper RPM dip..
Old Dec 3, 2002 | 07:14 PM
satan_srv's Avatar
Default Re: H23 VTEC dyno (Honda318dx)
Well it was a DC CC header, although I think the Tanabe G-Power Medallion was hurting up top...since I have a cutout thing but the motor is done...
Old Dec 3, 2002 | 08:07 PM
illusion's Avatar
graph says flywheel hp, not wheel hp.. =\
Old Dec 3, 2002 | 08:09 PM
satan_srv's Avatar
Default Re: H23 VTEC dyno (illusion)
That's what dynapack dynos say...it says SAE Hp on the scale
Old Dec 3, 2002 | 08:26 PM
4bidden's Avatar
For comparison...my buddy with a jdm h22, home depot intake, open greddy header, vafc, fpr, clutchnet clutch, jun flywheel just laid down 197/164 . That just goes to show you how you CAN hit 200whp with just bolt-ons....at least with a jdm motor
Old Dec 3, 2002 | 08:29 PM
user 9782082308's Avatar
Default Re: H23 VTEC dyno (4bidden)
What mods do you have on the engine?
Old Dec 3, 2002 | 09:08 PM
schwett's Avatar
New User
what are the two curves on each side? tuned and untuned? and why do dynapack dynos say "flywheel hp?" is there some built in correction factor it determines by measuring the "road hp" as well, like the old days?
Old Dec 4, 2002 | 02:37 AM
satan_srv's Avatar
Default Re: H23 VTEC dyno (schwett)
I'm not sure why it says flywheel, the HP scale is in SAE...no idea.
But the two curves are untuned and tuned. So all the gain there was through ecu tuning, which makes me wonder what the hell was wrong with my baseline..oh well.
Old Dec 4, 2002 | 05:56 AM
2point6's Avatar
Default Re: H23 VTEC dyno (Cottonwoodz)
I am not sure if that is directed to me or not, But my engine has well over 20K on it. BTW, this is a 2.44ltr not a 2.6
[Modified by 2point6, 6:57 AM 12/4/2002]
Old Dec 4, 2002 | 06:20 AM
aklucsarits's Avatar
New User
Default Re: H23 VTEC dyno (2point6)
2point6: That dyno plot is absolutely beautiful!! That's about as perfect as it gets. The torque is flat as a board (150lbft+ @2000rpm! ). The power curve has no sinkholes, and your A/F is flawless!
It looks like you put a lot of well-spent time and money into tuning. Did you tune it all yourself?
Is this motor still running? How many miles on this build?
Andrew
Old Dec 4, 2002 | 06:51 AM
2point6's Avatar
Default Re: H23 VTEC dyno (aklucsarits)
On one of my other sheets, we were able to get the dip (at the vtec crossover) to dissapear, But I can't find the sheet. For the tuning, we really spent very little time on it. I guess we were lucky. The tuning consisted of 1 cam adjustment which was a rough adjustment and minor VAFC adjustments. I guess we got lucky that day. Since then, I have added the SMSP header and a Euro R manifold so the tuning is most likely "whacked" right now. I hope to have it to the Dyno next week, but I have been saying that "I hope to get to the dyno" for a month now. Holiday season sucks.
Old Dec 4, 2002 | 08:23 AM
blackludeH22's Avatar
And for your info, 2point6 used to have a DC SPorts header that got him extra 2 horses, now with the SMSP header, type R intake ( I've seen it in person and it looked very nice) and the 68 mm throttle body, I won't be surprise to see this beast to hit 240+ at the wheel.
While we're at 200+ hp prelude, 2point6 is building my H22 as well, it has quite a few nice mods suggested and being done by him. It is a complete H22, and hopefully and very likely it will be around 200 whp. I will also post it when I get it dyno. Thanks to Scott!!!
[Modified by blackludeH22, 5:23 PM 12/4/2002]
Old Dec 4, 2002 | 12:03 PM
drift's Avatar
New User
becuase that dynopack software computes and corrects for flywheel hp, not whp.
SAE stands for "Standard American Equivalent", since HP is an American measurement of power. most other countries who didnt follow the SAE HP ratings used Newton Metres, PS (in japan), or Watts.
Old Dec 4, 2002 | 12:29 PM
satan_srv's Avatar
Default Re: H23 VTEC dyno (drift)
Hahahhaha...are you serious? You have absolutely no clue what you're talking about!
SAE stands for Society of Automotive Engineers
-Power is corrected to reference conditions of 29.23 InHg (99 kPa) of dry air and 77 F (25°C). This SAE standard requires a correction for friction torque. Friction torque can be determined by measurements on special motoring dynamometers (which is only practical in research environments) or can be estimated. When estimates must be used, the SAE standard uses a default Mechanical Efficiency (ME) value of 85%. This is approximately correct at peak torque but not at other engine operating speeds. Some dynamometer systems use the SAE correction factor for atmospheric conditions but do not take mechanical efficiency into consideration at all (i.e. they assume a ME of 100%).
So given your remarkable defintion of SAE, I'm curious as to what makes you think you know anything about a Dynapack Dyno?
[Modified by satan_srv, 4:30 PM 12/4/2002]
Old Dec 4, 2002 | 12:43 PM
drift's Avatar
New User
sorry, my mind is awash with BS right now... seems i shouldnt be posting while medicated.
Old Dec 4, 2002 | 03:45 PM
Ludester's Avatar
Default Re: H23 VTEC dyno (racerx)
Joel what are you running??? or is it top secret?
BTW nice numbers
Joe
[Modified by Ludester, 7:46 PM 12/4/2002]
Old Dec 4, 2002 | 04:16 PM
apexii's Avatar
Andrew
I could not agree more. That is an amazing plot. Torque curves don't get much flatter, and it's smooth as hell. Job well done.
Old Dec 4, 2002 | 04:18 PM
satan_srv's Avatar
Default Re: H23 VTEC dyno (Ludester)
Setup for this dyno:
Engine:
AEM CAI
64mm TB
Ported IM
RC 370cc injectors
P&P head
Crower Stage 3 (untuned cams)
Crower Valvetrain
AEM Cam gears
Arias 11.5 pistons in Darton Sleeves (87mm bore)
H23 crank + rods
Unorthodox Pulley
DC CC header
Tanabe G Power Exhaust
Custom GS-R p72 ecu
New Setup, full specs:
Block:
-H23A1 BLOCK
-F20B CRANK
-F20B RODS
-DARTON SLEEVES 87mm
-ARIAS FORGED PISTONS 11.5:1 COMPRESSION
-H22A1 OIL SQUIRTERS
-STOCK CRANK PULLEY
- H23A1 MANUAL TENSIONER
- POWER ENTERPRISE TIMING BELT
-8500 RPM REDLINE..FOR NOW
Head:
-H22A1 DOHC VTEC HEAD
-CROWER STAGE 3 CAMSHAFTS
-DUAL COIL VALVESPRINGS
-TITANIUM VALVE SPRING RETAINERS
-PORT AND POLISHED H22A1 HEAD
-3 ANGLE COMPETITION VALVE JOB
-ENTIRE MOTOR BALANCED AND LIGHTENED
-BALANCE SHAFTS REMOVED
-A/C REMOVED
Other:
-64MM BORE THROTTLE BODY
-PORTED INTAKE MANIFOLD
-370CC RC INJECTORS
-AEM FPR
-SKUNK2 CAM GEARS
-ARP STUD BOLTS
-CM STAGE 3 CLUTCH
-CM ALUMINUM FLYWHEEL 9LBS
-KAAZ LIMITED SLIP DIFFERENTIAL
-GSR ECU CHIPPED CUSTOM FUEL/SPARK OR HONDATA OR AEM EMS
-AEM CAI
-DC CC HEADER W/ HACK JOB GHETTO-STYLE ELECTRONIC STRAIGHT PIPE/OPEN HEADER
Old Dec 5, 2002 | 06:14 AM
2point6's Avatar
Just so people know, I did not post my dyno to "one up" satan srv, but thankyou for all the nice comments. This was mostly intended to show the potential of 2 different stroker set-ups. His set-up was a really nice one. Prospeed is another individual (shop) who has built stroker similar to satan srv's and made similar power to mine.
Old Dec 5, 2002 | 06:15 AM
satan_srv's Avatar
Yeah it's cool...your motor cost a lot more than mine did. And on top of that, it isn't my setup anymore so no worries...
Old Dec 5, 2002 | 06:26 AM
GraphiteAccord's Avatar
someday my car will be done. sooooommmmeeeeday...
PreLuDeKiDD16
Jan 10, 2005 09:04 PM
b18c1civic95
40
Dec 19, 2004 10:36 PM
laughinxxx
Jun 22, 2004 08:02 AM
tintin11
Jun 4, 2003 04:25 PM
AndyD
Jun 1, 2003 01:20 PM
