HELP!?! Will a crx SI alternator work...
Old Dec 3, 2002 | 06:43 AM
one.EG6's Avatar
Default HELP!?! Will a crx SI alternator work...
Will a CRX SI alternator work in a CRX with an LS motor? What would I have to do to make it work? swap pulleys would be a must, but what else? This has to be attempted ASAP, and I'd rather not attempt it without knowing for sure first...
any help is appreciated.. thanks!
Old Dec 3, 2002 | 09:10 AM
Flexmyrex's Avatar
Default Re: HELP!?! Will a crx SI alternator work... (one.EG6)
i used a si alt w my ls w/ ls belt . it worked ok till the belt got worn out cuz of the different teeth on the pulleys. found a cheap b16 alternator, it works.
you can goahead and swap the pulleys from ls to the si alternator, that should work fine.
Old Dec 3, 2002 | 11:14 AM
one.EG6's Avatar
Default Re: HELP!?! Will a crx SI alternator work... (flexmyREX)
cool. sounds good, thanks.
Old Dec 3, 2002 | 05:55 PM
boostinb18's Avatar
IFOY!!!!!!!
that is all!
and thanks one.EG6!!!
Old Dec 5, 2002 | 10:15 AM
one.EG6's Avatar
Default Re: HELP!?! Will a crx SI alternator work... (boostinb18)
IFOY!!!!
any time... sucker.
Chemi421
Aug 28, 2010 11:49 PM
civic1821
May 14, 2009 07:46 AM
one.EG6
Dec 3, 2002 05:56 PM
Flexmyrex
Aug 21, 2002 06:10 AM
enthusiast128
May 10, 2002 02:31 PM
