Bleeding Clutch.... but can't get Full Pedal Pressure. Help?
Old Dec 2, 2002 | 07:06 PM
PSU-TEG's Avatar
Default Bleeding Clutch.... but can't get Full Pedal Pressure. Help?
Ok,
When I'm bleeding my clutch, I can only achieve pedal pressure for the bottom half of the pedal tavel.
Am I doing something wrong?
I'm opening the bleed valve about a 1/4 or 1/8 or a turn, having someone slowly push the pedal to the flow, and shutting the bleed valve just before the pedal reaches the floor, then pulling the pedal back up, and repeating the cycle.
Any tips to get better pedal pressure.
Thanks!
Old Dec 2, 2002 | 07:09 PM
94TealGSR's Avatar
Default Re: Bleeding Clutch.... but can't get Full Pedal Pressure. Help? (PSU-TEG)
Just did my brothers today. You just leave the thing open and keep pumping the clutch. Once you get no air bubbles (or once it starts coming out a LOT if you have no tube), it's cool. Might help if you pull the clutch pedal all the way out when you pump it too. Be sure to keep filling the resovior as the level goes down steadily.
Old Dec 2, 2002 | 07:11 PM
PSU-TEG's Avatar
Default Re: Bleeding Clutch.... but can't get Full Pedal Pressure. Help? (94TealGSR)
Ok,
I thought pulling it up while the valve was opened would draw air back into the line.
But thanks, I'll give it a shot.
Old Dec 3, 2002 | 02:51 AM
Mista Bone's Avatar
D Tranny Guru
even me, the tranny guru was proven wrong. There is a check valve SOMEWHERE in the clutch system. I'll find it someday!
Old Dec 3, 2002 | 05:10 AM
Mover's Avatar
Default Re: Bleeding Clutch.... but can't get Full Pedal Pressure. Help? (Mista Bone)
Check valve in the clutch system ??
Old Dec 3, 2002 | 08:14 AM
MPower332TI's Avatar
Default Re: Bleeding Clutch.... but can't get Full Pedal Pressure. Help? (Mover)
Take a vacum tube and stick it on the bleeder tip. Then put the vacum line into a can of fluid so that the tube is submerged. Now pump the clutch a whole bunch and then hold it on the floor and turn the bleeder open. Repeat as neccescary. Shoudnt take much.
diviznrider
Feb 4, 2011 11:01 AM
ichiban_719
Nov 30, 2005 04:31 AM
draygenx
Mar 21, 2005 09:21 PM
RHEMU
Oct 16, 2003 03:40 AM
skierGT
Jul 23, 2003 12:29 PM
