JDM ITR aluminum AC bracket info for hybriders
Old Dec 2, 2002 | 05:09 PM
kenji's Avatar
25 Year Member
Default JDM ITR aluminum AC bracket info for hybriders
I recently test fitted a '92-'00 USDM Civic AC compressor on a JDM ITR aluminum AC bracket. This bracket will be great for people with '92-'00 Civics that want to install a DOHC B-series swap and keep the factory AC intact. It allows the Civic AC compressor to bolt up. This bracket costs the same as a '94-'95 DOHC VTEC Del Sol AC bracket, which does the same thing.
Threads need to be tapped into the holes that will be pointed out in the following pictures.
Here are some pics:
The picture above shows the AC bracket bolted to a B20 block.
The picture above shows one of the four holes that need to be tapped with a 8 X 1.25 threads to allow the AC compressor to bolt on.
The picture above shows the hole that needs to have threads tapped (12 x 1.25) for the idler pulley bracket.
The picture above shows the hole that needs to be drilled and tapped with a 8 X 1.25 tap to allow the tensioner bolt to thread in. You will need to use a washer to align the idler pulley and the crank pulley. Make sure the washer is JDM y0!
Next, a small amount of material needs to be remove for the AC compressor to clear. The next two pictures are a before and after shot of what needs to be done.
Before
After
Now your Civic AC compressor is ready to be bolted up to the JDM ITR aluminum AC bracket.
I know, I know the picture above doesn't have the material removed. It was the only pic I had without the AC compressor and at the same angle as the following pic.
Happy hybriding and be sure to visit your friendly online stores.
http://www.randdmotorsports.com
http://www.ipsracing.com
http://www.jdmspecperf.com
-kenji
Old Dec 2, 2002 | 05:18 PM
racecarpete's Avatar
Default Re: JDM ITR aluminum AC bracket info for hybriders (kenji)
good stuff
Old Dec 2, 2002 | 05:21 PM
97hb's Avatar
How much lighter is that one than the regular delsol vtec p54 bracket??? Thanks for the info mang .
Old Dec 2, 2002 | 05:22 PM
navin's Avatar
Default Re: JDM ITR aluminum AC bracket info for hybriders (97hb)
Old Dec 2, 2002 | 05:42 PM
97hb's Avatar
Default Re: JDM ITR aluminum AC bracket info for hybriders (navin)
Thanks mang
Old Dec 2, 2002 | 05:51 PM
neof69's Avatar
Nice Tech info.
Old Dec 2, 2002 | 05:56 PM
tonyxcom's Avatar
Default Re: JDM ITR aluminum AC bracket info for hybriders (neof69)
Best post in the EG forum in months!!!!!
Old Dec 2, 2002 | 06:00 PM
eg6sir-s's Avatar
praise the lord...
Old Dec 2, 2002 | 06:01 PM
vw-honda-hatches's Avatar
Default Re: JDM ITR aluminum AC bracket info for hybriders (tonyxcom)
so to retain A/C in my 95 cx when I swap my LS in there. I would need this???
Old Dec 2, 2002 | 06:35 PM
sleeprhatch's Avatar
Default Re: JDM ITR aluminum AC bracket info for hybriders (vw-honda-hatches)
fk i just bought the del sol bracket
yeah for other hybriders
Old Dec 2, 2002 | 06:43 PM
fakemike's Avatar
good stuff
Old Dec 2, 2002 | 06:47 PM
navin's Avatar
no. you can also use the Del Sol A/C bracket (forget which #), but using the Aluminum A/C mount you get to be mad JdM y0 and alot lighter..
Old Dec 2, 2002 | 06:54 PM
eg6sir-s's Avatar
kenji,
do you have any info on retaining ps pump off a civic(eg) and using it on a bseries block? similar to the ac bracket?
thanks
eg6si
Old Dec 2, 2002 | 07:45 PM
ITRinEJ1's Avatar
Default Re: JDM ITR aluminum AC bracket info for hybriders (eg6si)
kenji
Old Dec 2, 2002 | 08:22 PM
EkREV's Avatar
New User
Default Re: JDM ITR aluminum AC bracket info for hybriders (ITRinEJ1)
nice...now i have a project to work on before summer hits.
Old Dec 3, 2002 | 02:28 AM
kenji's Avatar
25 Year Member
eg6si,
All you need to do to retain your PS in your Si HB is use a GS-R PS pump and associated brackets and bolt your Si PS line up to it.
-kenji
kenji
Nov 2, 2010 12:35 AM
kenji
Dec 3, 2002 03:38 PM
rolow
May 14, 2002 11:25 AM
