Are exhaust silencers effective?
Silencers cut the flow of the exhaust down quite a bit...that's what makes the exhaust quiet.
Mine (T1R) works pretty well. The silencer removes a lot of the drone at freeway speeds, and also keeps the volume at a reasonable level. With the silencer removed the exhaust is pretty darn loud.
SO your saying that with the silencer you still feel a difference in power? I thought the silencer screwed in the end after the muffler and didn't effect the air flow
i dont know about affecting power(probably more torque), but with the silencer, that little hole is so small it reduces the exhaust flow-similar to stock size, making the sound quiet.
and lets be honest .. did anybody feel a big bost of power when you put your exhaust on ? I know I didnt put it on and say "WOW ..If I fix that nasty hole in my fuel curve Ill be running 9's"
i dynoed my RSR exhaust with the silencer and without
on the sohc vtec the losses were 4-5whp and 1-2lb/ft of torque
while on the b-series it was 7-8whp and 2-4lbs/ft of torque losses
the losses were only past 4500rpm
when driving on the streets silencer is your friend, at the track, who cares
_ enjoy the sound on open pipeTrending Topics
i have the skunk rsr for my eg, the silencer is by no means quiet, but it does take the egde off a loud exhaust, not near stock tough. withthe silencer on standing starts are easier b/c low end torque is restored, but there is basically no gain in power in vtech over stock. without the silencer you need to give it gas at lower rpms, but highwayacceleration is soooo much better. i just ride around w/out my silencer, the only reason i put it on was b/c i felt awkward making so much noise on public streets next to stock cars, but then i realized i dont car what people think
so let me just make sure im not taking this the wrong way, are you flaming me on a honda forum about having a vtech, or are you agreeing with me that vtech is a good thing.
Vtec is the variable valve timing that is found in select Honda and Acura models
I'm still NA for now but I've already got a custom 3" catback with N1 muffler. W/O the silencer it sets off car alarms weekly and I can't get **** for power under 4500RPM. With it in I don't set off car alarms and Ive got enough back presure to get around in traffic. The outlet of the silencer is only 2" so it can hurt the top end flow.
my silencer doesn't make THAT much of a difference but it might be the differance between a fix-it ticket and a warning. i have mines on, better safe than sorry
TEGPOWER44
Jan 20, 2003 08:47 PM
